New gas tank installment problems can you help? #1264401
07/08/12 10:23 PM
07/08/12 10:23 PM
sandusky ohio
mopardiebold Offline OP
sandusky ohio
I have a 68 Plymouth satillite that's been sitting since 2002 I put a new gas tank and sending unit and hoses and fuel pump and 6 gallons of gas and I blew out the lines back to front I cranked it over for 3 days now and I can't get gas up to fuel pump and filter any info would be appreciated thanks paul
Re: New gas tank installment problems can you help? [Re: mopardiebold] #1264402
07/08/12 10:45 PM
07/08/12 10:45 PM
Sometimes a worn pump will not prime at slow cranking speeds. Fill the carb bowls thru the bowl vents so it will run for 10 seconds or so & see if it will pump. If no go check the 2 neoprene lines on the hard lines and pull the pump & check the pushrod, no scalloped ends & the length when new is 3&1/4"
Re: New gas tank installment problems can you help? [Re: RapidRobert] #1264403
07/08/12 11:31 PM
07/08/12 11:31 PM
sandusky ohio
sandusky ohio
I have a new pump on the engine but I will fill the carb up it is a carter afb I fell the back up by the firewall correct ? Thanks paul
Re: New gas tank installment problems can you help? [Re: mopardiebold] #1264404
07/09/12 12:03 AM
07/09/12 12:03 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Take the fuel line loose at the pump, jack the car up on the drivers side to where the front line is lower than the fuel tank. Fuel should gush out of the line if it is not blocked. The line should be primed for the pump to pull fuel up to he carb. If it don't pump from here get ready to change a pump.
Re: New gas tank installment problems can you help? [Re: moparpollack] #1264405
07/09/12 12:57 AM
07/09/12 12:57 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Make sure its a NEW filter.
Second - try another new pump.
New tank, new sending unit and new lines = no restrictions. Therefore its down to the first two mentioned.
Let us know when you figure it out!
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: New gas tank installment problems can you help? [Re: WyleECoyote] #1264406
07/09/12 01:31 AM
07/09/12 01:31 AM
sandusky ohio
sandusky ohio
K thanks I'm at work now but will try when I get home how do you prime the line with a syphun hose? Thanks paul
Re: New gas tank installment problems can you help? [Re: mopardiebold] #1264407
07/09/12 08:15 AM
07/09/12 08:15 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Either you have leak on the suction side, or a short push rod if this is a BB. If sb maybe you have the fuel pump installed wrong?
Just Saturday I installed a gas tank with new lines on a sb challenger. I only had to crank it for less than minute to get gas to the carb and for it to start after I poured 5 gallons in the tank.
Also I hope you don't have a filter in front of your fuel pump, because it can't suck through a filter that is designed to go after the pump. Only the sock in the fuel tank should be between your pump and fuel tank.
Re: New gas tank installment problems can you help? [Re: mopardiebold] #1264408
07/09/12 04:53 PM
07/09/12 04:53 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Had the same issue... New tank, new lines, new pump. Cranked and cranked and it wouldn't pick up the gas. I hooked up a hand pump to the fuel line at the pump and pulled up some gas. Fired right up after that.
Paul
'69 Super Bee 383 EFI Turbo
Re: New gas tank installment problems can you help? [Re: Black_Bee] #1264409
07/09/12 05:40 PM
07/09/12 05:40 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I had this problem too. I ended up taking the fuel line off at the carb. I used an old oil can to inject fuel into the line until it wouldn't take any more. The engine fired off right away after that.
Re: New gas tank installment problems can you help? [Re: burdar] #1264410
07/09/12 05:42 PM
07/09/12 05:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
My pump was used and already was primed I bet?
Maybe it would help to squirt some oil into the inlet of the pump and pump it a few times before installing it onto the motor?
Re: New gas tank installment problems can you help? [Re: Challenger 1] #1264411
07/09/12 05:51 PM
07/09/12 05:51 PM
sandusky ohio
sandusky ohio
Ok thanks for all the replies thanks paul
Re: New gas tank installment problems can you help? [Re: mopardiebold] #1264412
07/09/12 06:32 PM
07/09/12 06:32 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Put many of fuel pumps on and never had to prime one of them. I would bet there is a small leak on the suction side.
Re: New gas tank installment problems can you help? [Re: mopars4ever] #1264413
07/11/12 02:02 AM
07/11/12 02:02 AM
sandusky ohio
sandusky ohio
This maybe a dumb question but any way I have the carb full of gas and it still won't start I have the alternator off does the alternator need to be on and the wires pluged in for it to fire I don't think so but thought I'd ask the car does have the msd box. Thanks again paul
