70 Charger 500 Tail Panel numbers ; Updated #1264182
07/08/12 03:03 PM
07/08/12 03:03 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
Restoring the tail panel on my 70 Charger 500 and the original holes were filled in poorly by previous owner and "500" replaced with the standard Charger script with medallion emblem.
I've stripped it down and located the holes;
Question is, the "Charger" and "500" appears to be separate? If separate, where can I get a "500" badge? Or both?
The "500" on the grill IS larger than what would be on the rear.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: Hoof Hearted] #1264183
07/08/12 11:05 PM
07/08/12 11:05 PM
S.E. Conn
S.E. Conn
Stripped entire panel with a 24 hour soak in Brake Fluid;
Any recommendations on what detergent/cleaner to use to rid of any residual brake fluid or contaminants before priming and painting?
2005 300C Hemi
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: Hoof Hearted] #1264184
07/09/12 11:33 AM
07/09/12 11:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
brake clean...spray it on a rag..wipe. the wash it w/ soap and water rinse..dry paint. Heres mine after a coat of new satin black.
Coming soon!!!!
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: Mr.Yuck] #1264185
07/13/12 12:47 PM
07/13/12 12:47 PM
S.E. Conn
S.E. Conn
Here's some updates for anyone interested in future 70 charger restos
2005 300C Hemi
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: Hoof Hearted] #1264186
07/13/12 12:49 PM
07/13/12 12:49 PM
S.E. Conn
S.E. Conn
Used the existing Left 2 mounting hole for "Charger" script and had to modify slightly the Right 2 mounting holes to mount the Repo ($30 on Ebay) "500" script.
Also, note the Emblems aren't quite centered; Could this have been an R/T tail panel?
On second pic (installed with no tail light gaskets yet) you can see the light housing is off a bit, i'll be widening out mounting the holes on final install.
2005 300C Hemi
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: Hoof Hearted] #1264187
07/13/12 06:35 PM
07/13/12 06:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your panel looks correct for a 500 panel, I have 2 untouched/original Charger 500 panels, both look identical as to how you've finished yours with regards to the script placement
Mike
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: DAYCLONA] #1264188
07/24/12 01:57 PM
07/24/12 01:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I stripped mine with Brake clean on my R/T 22 years ago & repainted it. Still looks good. My other 70 is a 500 S.E. & has this same tail panel.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: 6PKRTSE] #1264189
07/24/12 01:58 PM
07/24/12 01:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Appears to be seperate. Here is a picture of my other 70 500 S.E. panel. Car is all original & in rough condition.
Re: 70 Charger 500 Tail Panel numbers ; Updated [Re: 6PKRTSE] #1264190
07/24/12 02:02 PM
07/24/12 02:02 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Picture of my other 70 500 S.E. as it sits in storage.
