Lower Control Arm Bushings #1264114
07/08/12 01:58 PM
07/08/12 01:58 PM
indy
E
edco440 Offline OP
edco440  Offline OP
E
indy
Can anyone please tell me which LC Arm Bushings I should get? I buy almost all my suspension and Chassis parts from Dick Ross,(Firm Feel) or Cass Eslick,(Dr. Diff). I noticed Firm Feel has Nylon Bushings as well as Poly-Urethane. Which ones should I get? I want the most durable material. The Car is a true street, high HP car, with manual 5-Speed, B-Engine with a lot of alloy parts. Thanks,,Eddie
Re: Lower Control Arm Bushings [Re: edco440] #1264115
07/08/12 04:03 PM
07/08/12 04:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Leave the rubber for the resto crowd, I'd recommend the Poly's, that's all I have run the last 25+ years for a well rounded street/strip/track car, if your ride is track/course dedicated, go nylon
Re: Lower Control Arm Bushings [Re: DAYCLONA] #1264116
07/08/12 05:10 PM
07/08/12 05:10 PM
IN
ahy Offline
ahy  Offline
IN
I run and like the poly. Depending on tolerence and stackup, however, the strut rod may not hold the LCA in snug with poly. An adjustable strut rod is the fix.
If you don't have adjustable strut rods and don't want to (maybe) find out by trial and error that you need them, go with the rubber.
Re: Lower Control Arm Bushings [Re: ahy] #1264117
07/08/12 05:15 PM
07/08/12 05:15 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
How would someone know they need the adjustable strut rod to fix any problems the poly LCA bushing might cause?
What are the symptoms can they be found while doing a front end alignment or is it the LCA moves around when the car is going through different ranges of motion while driving on the street or a track course?
Re: Lower Control Arm Bushings [Re: PHJ426] #1264118
07/08/12 05:24 PM
07/08/12 05:24 PM
IN
ahy Offline
ahy  Offline
IN
In my case, I couldn't bring the alignment in and it wandered a bit when cornering on an uneven road.
I found the problem by visual inspection. With the front wheels on ramps, I could see a gap of almost 1/8" between the shoulder of the bushing and LCA on the left side. The inboard side of the LCA was out of position and free to slide around. Adjustable rods fixed it. I adjusted the rods to bring the bushings in snug then added just a very little pre load with a final check for binding before re-installing the T bars.
Alignment cam in perfectly and she is steady in the twisties.
Re: Lower Control Arm Bushings [Re: ahy] #1264119
07/08/12 07:05 PM
07/08/12 07:05 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Adjustable strut rods are a nice addition, but if all you need to do is prevent fore and aft movement of the bushings on the LCA pivot bolt simply drive the torsion bars ALL THE WAY into the LCA when you install them, not just simply enough to clear the "C" clips in the crossmember. Once you put preload on the "T" bars they wont allow the LCA to move fore or aft.
Re: Lower Control Arm Bushings [Re: edco440] #1264120
07/08/12 07:15 PM
07/08/12 07:15 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
One lone vote here for keeping the OE-style rubber LCA bushings. There is very little rubber [and therefore flex] in them.
Although usually solvable, the non-rubber style often bring challenges not found when sticking with OE style rubber. Earlier in this thread, you will read as others mention these problems, and the suggested solutions for those problems. If you stick with rubber in the LCA application, you can avoid all of that in the first place.
The problem in this other thread might perhaps be from non-standard LCA bushings.
Down to just a blue car now.
Re: Lower Control Arm Bushings [Re: 68HemiB] #1264121
07/08/12 07:48 PM
07/08/12 07:48 PM
LI, new york
gmachinedart1 Offline
LI, new york
In my own opinion this is one of the most important bushings to consider.I feel there are extreme loads placed on this bushing which translate in LCA deflection and camber/ possible toe changes during hard cornering.This translates into positive camber and loss of tire contact patch on the loaded outside tire.I have been using the nylon greasable bushings offered by Firm Feel for quite some time now with great results and no problems.These in combination with an adjustable heim mounted strut rod to help control caster changes should work great for you.Good luck.
Re: Lower Control Arm Bushings [Re: edco440] #1264122
07/09/12 09:22 PM
07/09/12 09:22 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I am well aware that alternate LCA bushings have many proponents.
Despite the PM from another member that this argument is always an exercise in futility, I will respectfully suggest that the O.P. take a quality oe-style LCA bushing in hand, and note the amount of rubber between the two shells and the density of that rubber. Consider for yourself the likelihood of compression of that rubber, the probable degree of that compression, and the movement that might result.
Consider then the frequency of posts asking about the source of the mysterious front-end noise on cars with alternate material in the LCA bushing.
Also consider the frequency of posts asking how to correct the movement seen in applications using an alternate LCA bushing.
And then consider the frequency of posts defending alternate LCA bushings, with [often unsolicited] explanations of the additional steps one should take to avoid issues with them.
Alternate materials are great for most other suspension applications.
So ends the lone vote, lost in the wilderness.
Re: Lower Control Arm Bushings [Re: 68HemiB] #1264123
07/10/12 01:31 AM
07/10/12 01:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And I'll waste my time posting a couple pictures the first being a Mopar LCA which as noted by Steve hasn't got allot of rubber in it to deflect... But does have the ability to properly locate the inboard end of the LCA..
Re: Lower Control Arm Bushings [Re: 1_WILD_RT] #1264124
07/10/12 01:32 AM
07/10/12 01:32 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And next a set of GM LCA bushings which are worth replacing with something other than rubber.....
Re: Lower Control Arm Bushings [Re: 1_WILD_RT] #1264125
07/10/12 07:05 AM
07/10/12 07:05 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
The non stock bushing people who claim that the stock bushings are junk and that the stock lca bushings should not be used should go collect 20 years of chasing turns at Watkins Glen and then come back and tell us what they learned.
I have plenty of experience putting the stock lca bushings under real duress with no problems. If the alignment angles were not being held properly by the stock bushings it would show up in the car's handling and the tire wear. It's not happening. When the vehicles are checked on the alignment machine after being tracked there are no changes in the original settings. I must be lucky...
Re: Lower Control Arm Bushings [Re: ThermoQuad] #1264126
07/10/12 09:26 AM
07/10/12 09:26 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I've noticed a dfference since swapping to poly -
when I did my car 15 years ago i did it all poly, except for the LCA -
after 12 years I replaced the front end and guess what the only worn piece was? yup the rubber lca bushings.
I have the just suspension lca pivot shafts and they fit great without any slop anyone is referring to.
Re: Lower Control Arm Bushings [Re: DJVCuda] #1264127
07/10/12 10:40 AM
07/10/12 10:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
What I've noticed is that rubber bushings are all made to OEM specs, so they ALWAYS fit and work.
Poly bushings are made to fit in different ways and of different types of poly. There is no consistency in how they need to be made to fit among the different manufacturers and you really need to be observent of the particulars of how the lower arm bushings go together and how your poly needs to interface with the bushing shells and arms to successfully make poly work. But if you pay attention to the install, they can be made to work quite well.
Different strokes for different folks.
BTW, I do agree that in GM applications it is a much bigger necessity than in a mopar.
Re: Lower Control Arm Bushings [Re: TC@HP2] #1264128
07/10/12 11:07 AM
07/10/12 11:07 AM
indy
E
edco440 Offline OP
edco440  Offline OP
E
indy
Wow, thanks to ALL for the very informative posts! I will show what I bought and pics of the finished assembly when done.
Re: Lower Control Arm Bushings [Re: edco440] #1264129
07/10/12 05:28 PM
07/10/12 05:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Surprised "Delrin" bushings have not been mentioned, which I run, but don't have enough miles to comment on durability. It is likely all a arraigning the deck chairs on the titanic issue anyway
Re: Lower Control Arm Bushings [Re: jcc] #1264130
07/10/12 09:57 PM
07/10/12 09:57 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i put all poly in one car and all moog rubber in the other, i honestly dont notice a difference. i have not had the problems with the poly lower but i decided to try the moog rubber tghe second time around since i was using the offset upper bushings. not only is there not a lot of rubber in them, its pretty hard for rubber.
Re: Lower Control Arm Bushings [Re: jcc] #1264131
07/12/12 11:42 PM
07/12/12 11:42 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I had a full set of delrin bushings (front and rear) on a different car that was my daily driver for about 7 years. As long as they are greaseable, the delrin lasts a long time. I probably put about 40k miles on the ones in that car, never had to replace any of them. Just be prepared for the amount of road noise that is transmitted (especially from the rear axle) through those bushings. Not a concern on a pure race car, but can get annoying on long drives in a street car.
BTW - I would also vote for the stock LCA rubber bushing.
