Broken stud in block - NE1 in Sea/Tac area with welder? #126344
09/26/08 02:06 AM
09/26/08 02:06 AM
Vancouver, WA
MoparMarq Offline OP
Vancouver, WA
Hey there,
I've got a broken stud in the engine block. It's at the back where the bellhousing bolts on. Fortunately, the engine is out of the car so it's easy access. But a couple of hours a day for the last couple of days with the 5/32 drill bit has gotten a hole maybe a 1/16" deep. I'm thinking the better way is weld on a washer, then a nut, and turn it out.
Got a good washer (thick fender washer with hole just slight smaller than stud size) and a decent nut. Only problem is...I don't own a welder, nor do I know how to weld.
Any help/suggestions here? Anyone want to make some gas money?
TIA,
Marq
Re: Broken stud in block - NE1 in Sea/Tac area with welder? [Re: MoparMarq] #126345
09/26/08 06:49 AM
09/26/08 06:49 AM
ky.
K
kenworth_goose Offline
K
ky.
Get a new drill bit that will drill the bolt and than go to the next size up until it comes loose.
Re: Broken stud in block - NE1 in Sea/Tac area with welder? [Re: kenworth_goose] #126346
09/26/08 07:08 AM
09/26/08 07:08 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Start the pilot hole with a smaller bit, 1/16 or so and work up from there. Go slow and dont break the bit. You'll be fine.
Re: Broken stud in block - update... [Re: MoparMarq] #126347
09/26/08 05:21 PM
09/26/08 05:21 PM
Vancouver, WA
Vancouver, WA
I thought about continuing the drilling saga...
But instead of spending HOURS in the garage fixing something I screwed up (when I'd rather be spending that time with my 4- and 2-year old daughters), I called up a welder locally to weld on a washer to the remainder of the stud.
He shows up at 1:00 pm. Badda bing, badda boom!
The stud is out by 1:30 pm.
Wouldn't do it any other way ever again. (Don't ask what it cost me, but the girls will only be little once - and it's over much too fast.)
pics follow...
Re: Broken stud in block - update... [Re: MoparMarq] #126348
09/26/08 05:26 PM
09/26/08 05:26 PM
Vancouver, WA
Vancouver, WA
Pic above is after 4 hours of slow drilling (and 3 bits and plenty of cutting oil.)
Pic below is stud removed after the washer was welded on. Undoubtedly, the heat from the weld helped loosen the stud in the block. We didn't even have to weld a nut to get a satisfactory purchase on the washer. Vise clamps did the trick.
Re: Broken stud in block - update... [Re: MoparMarq] #126349
09/26/08 05:31 PM
09/26/08 05:31 PM
Vancouver, WA
Vancouver, WA
Good as new.
Now to make sure my torque wrench is properly calibrated. The "click" is not as noticeable as it once was...
If you've got a welder and a modicum of skills, this was the way to do it, no question. WAY easier!
Re: Broken stud in block - update... [Re: MoparMarq] #126350
09/26/08 05:42 PM
09/26/08 05:42 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Be careful bolting the bell housing back on. It may crack since the surface is uneven.
Re: Broken stud in block - update... [Re: mopars4ever] #126351
09/26/08 08:13 PM
09/26/08 08:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've seen a few blocks with that off-machined area, may be factory. That bolt looks like it may have been on the long side, don't it?
Re: Broken stud in block - update... [Re: mopars4ever] #126352
09/26/08 09:57 PM
09/26/08 09:57 PM
Vancouver, WA
Vancouver, WA
That's not an illusion. It is uneven. But it's machined that way, and the low surface part is beyond the bolt center. The bottom bolt on the same side has the same look. It appears specifically made that way to accommodate a starter gap plate made of probably .030" or .040" sheet metal stock.
With the bellhousing back on, without the bolts being torqued, the bellhousing fits flush and clean against the block, with the allowance for the starter gap plate.
