Turbo Action SCS shifter question?????? #1263373
07/07/12 11:24 AM
07/07/12 11:24 AM
birdtracker Offline OP
wanted to ask other owners if their shifter would go from 1st to nuetral then to reverse without doing anything other than moving the shifter. This is of course a PRN123 pattern. While sitting mine will go from 1st thru nuetral then reverse. Just asking. Thanks. Birdtracker
Re: Turbo Action SCS shifter question?????? [Re: birdtracker] #1263374
07/07/12 12:13 PM
07/07/12 12:13 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
1st to neutral, yes but, you should have to squeeze the
"T" under the handle to get past the lock-out gate.
You either have the cable way out of adjustment or possibly
the wrong gate?
Re: Turbo Action SCS shifter question?????? [Re: S/ST 3040] #1263375
07/07/12 12:18 PM
07/07/12 12:18 PM
thank you. I will try a couple different adjustments and see what happens. Birdtracker
Re: Turbo Action SCS shifter question?????? [Re: birdtracker] #1263376
07/07/12 03:35 PM
07/07/12 03:35 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
The "T" under the handle may be stuck in the up position. Make sure it slides up and down without any drag. Mine started to hang up and I had to take it apart and widen the groove where the roll pin goes.
Raul
Re: Turbo Action SCS shifter question?????? [Re: Aspen7695] #1263377
07/07/12 06:47 PM
07/07/12 06:47 PM
I never thought of that. The car shifts fine, and you have to squeeze the T to get out of park into reverse but after that R-N-1 there is nothing. Thanks for the idea. Birdtracker
Re: Turbo Action SCS shifter question?????? [Re: birdtracker] #1263378
07/07/12 10:43 PM
07/07/12 10:43 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Here is a pic of a spare 727 reverse manual gate plate I have. The shifter should move from park to reverse without having to lift up the handle, you should then have to lift the handle to get over the detent for neutral.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Turbo Action SCS shifter question?????? [Re: Plumb Wired] #1263379
07/07/12 10:59 PM
07/07/12 10:59 PM
thats interesting as I have to raise mine to get out of park into reverse. Thanks for the info. Birdtracker
Re: Turbo Action SCS shifter question?????? [Re: birdtracker] #1263380
07/08/12 08:58 AM
07/08/12 08:58 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
There are 2 different gates that will work with the 727...There other style 'springs' right into 1st, straight back into second, then pull left and down into 3rd. This style also is used for the C4 Ford.
Re: Turbo Action SCS shifter question?????? [Re: HardcoreB] #1263381
07/08/12 09:26 AM
07/08/12 09:26 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
That is the gate I have in my Dart for use with the clean neutral valve body. You should still be able to go straight from park to reverse and lift the detent to get to the forward gears.
Mike Gray
RIP Monte Smith
aka: OutlawFish
Re: Turbo Action SCS shifter question?????? [Re: Plumb Wired] #1263382
07/08/12 09:27 AM
07/08/12 09:27 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Here is a pic from T/A's site showing the Chrysler gates.
RIP Monte Smith
aka: OutlawFish
Re: Turbo Action SCS shifter question?????? [Re: Plumb Wired] #1263383
07/08/12 10:12 AM
07/08/12 10:12 AM
thanks for all the help and pms. Does anyone have one of the plastic consoles with the switches they are not using? thanks. Birdtracker
