Re: Ballast resistor question
[Re: GKMOPAR]
#1263356
07/07/12 10:53 AM
07/07/12 10:53 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
The MP dist comes with the correct resistor.I believe it is about 1.2 ohms.No need for a dual resistor.That was used in later apps.One for a 71 should be single and work.Rocky
Chrysler Firepower
[Re: mikemee1331]
#1263358
07/07/12 04:59 PM
07/07/12 04:59 PM
RapidRobert
Might peruse the "ballast resistor bypass" thread on page 2 (has over 50 comments!). Yes the MP ballast for the chrome/orange box has a nominal ohms listing of 1.25 ohms but may (& probably will) vary from that (new or used) a certain amount and you do have a fair amount of leeway. Carry a spare ECU/ballast in the glove box!
[Re: 1970sixpak]
#1263362
07/08/12 03:07 AM
07/08/12 03:07 AM
Posts: 10,214 Someplace you aren't
SomeCarGuy
It all depends on what ignition componets you are running. It also depends on if you read the information on those parts, and not go off of what somebody said years ago that might apply if you were running the specific pieces they are referencing.
I want my fair share
[Re: SomeCarGuy]
#1263363
07/08/12 08:48 AM
07/08/12 08:48 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
and a 1.7 would work fine. the higher the resistance, the less current, the less heat. but too high and there will be a performance trade off.
