OK so i was told that my bell housing might not fit my 833 od tranny, so i yanked the bell housing out of my 89/90 dodge which is a hydro clutch set up an it fits right on there, it has 2 diffrent set of bolt holes as well, the 2nd bolt holes line up with the bolt holes of the 833 is this normal?? i don't want to run a hydro clutch on this project as i was saving it for my 85 4x4.. i am kind of new to Dodge's so take it easy hahaha.. what year's of bellhousing's should i look for that my 833 OD will built up an that will bolt up to a small block?? all of this will be going in to a 84 short box 2wd that originally had a /6 with a np45 trans
