schwartz performance What do you think? #1263259
07/06/12 10:26 PM
07/06/12 10:26 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Looking to build a car or do i buy a used SRT8 Challenger.I love 70 Road Runners. So can i build one to handle like a new car? My brother told me about this schwartz performance.Do you go down that road or can you piece together a car with parts. Sent them a email and they have E and B boddy frames. Told me $2-4k to put a full frame under the car with suspension.lets here the pros and cons. thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: schwartz performance What do you think? [Re: hulmule] #1263260
07/06/12 10:51 PM
07/06/12 10:51 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I see $9,199 as a base price. And you still have to have fixture and mount your rear end. Still have to make a steering column and other "stuff" from what I can see at just a glance.
Re: schwartz performance What do you think? [Re: autoxcuda] #1263261
07/06/12 11:03 PM
07/06/12 11:03 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
http://schwartzperformance.com/mopar-b-body/
Pricing:
Base Price: $ 9,199.00
Disc Brake Kit:
13″ Plain rotor, 6 piston front, 4 piston rear Wilwood (+$2,669)
13″ cross-drilled OR slotted, 6 piston front, 4 piston rear Wilwood (+$2,969)
14″ cross-drilled, Baer 6P Calipers (+$4,500)
14″ cross-drilled, Baer 6S Calipers (+$7,995)
Coilover Shocks/ Springs:
None ($0)
RideTech Single-Adjustable (+$1,300)
RideTech Triple-Adjustable (+$2,600)
Rear End Housing & Axles:
None; weld your brackets to my housing (+$189)
Moser full-floating 9″, 31 spline axles (+1,814)
Moser M9 full-floating 9″, 31 spline axles (+2,304)
Heidts IRS, Installed (+$8,495)
Third Member/Differential:
None
Trac Lock posi, cast iron case +($995.00)
Detroit TrueTrac, cast iron case +($1295.00)
Detroit TrueTrac, Moser spec w/ nodular case +($1495.00)
Detroit TrueTrac, Moser spec w/ aluminum case +($1695.00)
Rear End Ratio:
None
3.25:1
3.50:1
3.70:1
3.89:1
4.10:1
4.56:1
Motor Mounts:
New Hemi 5.7/6.1 +($145.00)
Old-school Hemi +($145.00)
Other
Powdercoat:
No powdercoat, bare steel
Your choice of colors +($1,600)
Assembly:
I’ll assemble myself
Please assemble my chassis +($595.00)
Payment terms: 75% down at time of order, remaining 25% due before shipment.
Re: schwartz performance What do you think? [Re: autoxcuda] #1263262
07/06/12 11:03 PM
07/06/12 11:03 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Link?
Re: schwartz performance What do you think? [Re: moparpollack] #1263263
07/06/12 11:15 PM
07/06/12 11:15 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
If you are into spending cubic dollars as a basis for improving your car this (Schwarts Performance $$$$) is definitely the way to go.
There are also these alternatives if your into the package deal systems:
http://www.hotchkis.net/search.html?Make=49&Model=1338&SubmitForm=Search
http://www.xvmotorsports.com/products/index.cfm
http://firmfeel.com/b.htm
Get AndyF's book on the B body handling and read all you can on this forum on Moparts and other locations on Mopars that handle. You dont need to put a full frame under your car........if that is what you want to do well then go ahead and do it but its not required just because Schwartz says sooooooooo
Re: schwartz performance What do you think? [Re: moparpollack] #1263264
07/06/12 11:20 PM
07/06/12 11:20 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
wow, got to go and look at that. his email didnt sound like that.That being said , i guess need to look else where. That SRT8 is looking better, with the big brakes, etc jump in and drive.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: schwartz performance What do you think? [Re: hulmule] #1263265
07/06/12 11:44 PM
07/06/12 11:44 PM
IN
ahy Offline
ahy  Offline
IN
$2-4k will get you a really good T-bar/spring/steering setup that can handle with current cars. No additional parts/frames ect. needed. Add wheels, tires and powertrain...
Total cost is likley to be higher to restore and upgrade the older car vs a used newer car. It comes down to what you want... an older car that handles and stops really well or a newer car?
Re: schwartz performance What do you think? [Re: ahy] #1263266
07/07/12 12:06 AM
07/07/12 12:06 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Like ahy said you dont need that much to get the suspension and steering up to snuff. This all depends on the car you are starting with.
You might just find a great deal on the board. Do you already have the 70 Road Runner of no? So all this $$$$ depends on how nice of a car you start with mechanically speaking....
Re: schwartz performance What do you think? [Re: hulmule] #1263267
07/07/12 12:34 AM
07/07/12 12:34 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I think the 2-4 grand is for the labour to install the parts on your car, not purchase them.
Get the SRT8 and enjoy, you'll end up with as much money into the old car and it won't likely outperform the new one, Plus you can start driving it the day you buy it.
A new iron curtain drawn across the 49th parallel
Re: schwartz performance What do you think? [Re: 67autocross] #1263268
07/07/12 02:19 PM
07/07/12 02:19 PM
NY NY
3
340duster340 Offline
NY NY
my dad has the srt8 challenger, its a blast to drive. 6 speed, etc.
you couldn't resto-mod an old car and upgrade to the same performance and reliability for what he paid for his. plus factory warrantee if your buying new or CPO.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: schwartz performance What do you think? [Re: PHJ426] #1263269
07/07/12 04:57 PM
07/07/12 04:57 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Disc Brake Kit:
None
Rear End Ratio:
3.70:1
Motor Mounts:
Powdercoat:
Assembly:
Looks like the cheap options and putting it all together yourself costs you $17,722.00. I'd call that almost half way to a used R/T Challenger.
Disc Brake Kit:
Rear End Ratio:
3.70:1
Motor Mounts:
Powdercoat:
Assembly:
If you go the fully optioned route, it adds up to $32,324.00. Thats a lot of coin for only marginal performance gain over what you can do to the stock system for $4000. Of course the Schwartz guys will spout off about their adjustablity and geometry changes and how that all is head and shoulders above stock stuff.
For your 70 Roadrunner, including vehicle purchase, restoration, and rebuild costs, and your classic could easily top $100k using the figures above.
Re: schwartz performance What do you think? [Re: TC@HP2] #1263270
07/07/12 08:18 PM
07/07/12 08:18 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Actually you can buy a resto modded Mopar for about the same cash you would spend with this frame company. Here on Moparts in the 71 and up B body this car is available not mine and I dont know the guy that built it but here you go:
71 roadrunner srt 6.1 hemi conversion
all of the goodies:
alterkation
TTI
wilwood - all 4 corners
Challenger SRT interior
AC. Power windows
518 O.D.
Build up is posted in member projects section of this board.
Was featured in Jan 2012 Chrysler power magazine.
ASKING $36k (you may be surprised what I may sell this car for....to the right person!)
PM here or call 813 434 6668
thanks
Re: schwartz performance What do you think? [Re: PHJ426] #1263271
07/07/12 10:33 PM
07/07/12 10:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Art Morrison has kits for Mopars too.
Mopar to the bone!!!
Re: schwartz performance What do you think? [Re: PHJ426] #1263272
07/08/12 06:42 AM
07/08/12 06:42 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
all of the goodies:
alterkation
TTI
AC. Power windows
518 O.D.
thanks
this car is sick - I would buy it!
Re: schwartz performance What do you think? [Re: dangina] #1263273
07/08/12 05:18 PM
07/08/12 05:18 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
all of the goodies:
alterkation
TTI
AC. Power windows
518 O.D.
thanks
No doubt, anyone can have a new Challenger just sign here.............
That 71 Road Runner is a good looking ride!
Re: schwartz performance What do you think? [Re: PHJ426] #1263274
07/08/12 07:48 PM
07/08/12 07:48 PM
"Your Mopar’s uni-body construction is inherently weak. Our G-Machine Chassis isn’t."
Wow, really!?
While in stock form it leaves a lot to be desired, I think I could spend $9k+ and have a uni-body that is more than up to the task!
Re: schwartz performance What do you think? #1263275
07/08/12 10:19 PM
07/08/12 10:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A ladder frame is strong?
LOf'iingL
Looks like a great way to p!ss away lots of money.
Cracker Jack U strikes again.
Don't be the exception.
Re: schwartz performance What do you think? [Re: Supercuda] #1263276
07/08/12 10:35 PM
07/08/12 10:35 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
This Schwartz guy must be a great snake oil salesman.
With these kind of engineering skills he possesses I wonder what he would tell Boeing about designing aircraft frames.......
Re: schwartz performance What do you think? [Re: PHJ426] #1263277
07/09/12 01:26 AM
07/09/12 01:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Re: schwartz performance What do you think? [Re: Kern Dog] #1263278
07/09/12 05:01 PM
07/09/12 05:01 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Like most all build vs. buy questions, the answer depends on these things:
1. Do you enjoy building cars?
2. Is the concept more important to you than the money?
3. Do you want to enjoy the end product now, or is the journey to get there part of your enjoyment?
4. Will you actually explore the limits 100% at the track, or is it a street car?
It's almost always less expensive to buy a finished project, like the '71 B mentioned, IF it's done right and it's to your taste. You need to set the goals & budget. I can appreciate the new stuff, but to me old cars are WAY cooler and usually a better investment. I've built enough cars to feel confident that I can do an early Camaro, Mustang, Challenger, etc that would equal the new models' performance for about the same money.
