schwartz performance What do you think?
#1263259
07/06/12 10:26 PM
07/06/12 10:26 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
Looking to build a car or do i buy a used SRT8 Challenger.I love 70 Road Runners. So can i build one to handle like a new car? My brother told me about this schwartz performance.Do you go down that road or can you piece together a car with parts. Sent them a email and they have E and B boddy frames. Told me $2-4k to put a full frame under the car with suspension.lets here the pros and cons. thanks
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: schwartz performance What do you think?
[Re: hulmule]
#1263260
07/06/12 10:51 PM
07/06/12 10:51 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
I see $9,199 as a base price. And you still have to have fixture and mount your rear end. Still have to make a steering column and other "stuff" from what I can see at just a glance.
[Re: autoxcuda]
#1263261
07/06/12 11:03 PM
07/06/12 11:03 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
http://schwartzperformance.com/mopar-b-body/Pricing: Base Price: $ 9,199.00 Disc Brake Kit: 13″ Plain rotor, 6 piston front, 4 piston rear Wilwood (+$2,669) 13″ cross-drilled OR slotted, 6 piston front, 4 piston rear Wilwood (+$2,969) 14″ cross-drilled, Baer 6P Calipers (+$4,500) 14″ cross-drilled, Baer 6S Calipers (+$7,995) Coilover Shocks/ Springs: None ($0) RideTech Single-Adjustable (+$1,300) RideTech Triple-Adjustable (+$2,600) Rear End Housing & Axles: None; weld your brackets to my housing (+$189) Moser full-floating 9″, 31 spline axles (+1,814) Moser M9 full-floating 9″, 31 spline axles (+2,304) Heidts IRS, Installed (+$8,495) Third Member/Differential: None Trac Lock posi, cast iron case +($995.00) Detroit TrueTrac, cast iron case +($1295.00) Detroit TrueTrac, Moser spec w/ nodular case +($1495.00) Detroit TrueTrac, Moser spec w/ aluminum case +($1695.00) Rear End Ratio: None 3.25:1 3.50:1 3.70:1 3.89:1 4.10:1 4.56:1 Motor Mounts: New Hemi 5.7/6.1 +($145.00) Old-school Hemi +($145.00) Other Powdercoat: No powdercoat, bare steel Your choice of colors +($1,600) Assembly: I’ll assemble myself Please assemble my chassis +($595.00) Payment terms: 75% down at time of order, remaining 25% due before shipment.
[Re: autoxcuda]
#1263262
07/06/12 11:03 PM
07/06/12 11:03 PM
moparpollack
Lil Herman
Lil Herman
85086
Link?
[Re: moparpollack]
#1263264
07/06/12 11:20 PM
07/06/12 11:20 PM
hulmule
northeast ohio
wow, got to go and look at that. his email didnt sound like that.That being said , i guess need to look else where. That SRT8 is looking better, with the big brakes, etc jump in and drive.
[Re: hulmule]
#1263267
07/07/12 12:34 AM
07/07/12 12:34 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I think the 2-4 grand is for the labour to install the parts on your car, not purchase them.
Get the SRT8 and enjoy, you'll end up with as much money into the old car and it won't likely outperform the new one, Plus you can start driving it the day you buy it.
A new iron curtain drawn across the 49th parallel
[Re: PHJ426]
#1263269
07/07/12 04:57 PM
07/07/12 04:57 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
Base Price: $ 9,199.00 Disc Brake Kit: 13″ Plain rotor, 6 piston front, 4 piston rear Wilwood (+$2,669) Coilover Shocks/ Springs: RideTech Single-Adjustable (+$1,300) Rear End Housing & Axles: Moser full-floating 9″, 31 spline axles (+1,814) Third Member/Differential: None Trac Lock posi, cast iron case +($995.00) Rear End Ratio: 3.70:1 Motor Mounts: Old-school Hemi +($145.00) Powdercoat: Your choice of colors +($1,600) Assembly: I’ll assemble myself
Looks like the cheap options and putting it all together yourself costs you $17,722.00. I'd call that almost half way to a used R/T Challenger.
Base Price: $ 9,199.00 Disc Brake Kit: 14″ cross-drilled, Baer 6S Calipers (+$7,995) Coilover Shocks/ Springs: RideTech Triple-Adjustable (+$2,600) Rear End Housing & Axles: Heidts IRS, Installed (+$8,495) Third Member/Differential: Detroit TrueTrac, Moser spec w/ aluminum case +($1695.00) Rear End Ratio: 3.70:1 Motor Mounts: New Hemi 5.7/6.1 +($145.00) Powdercoat: Your choice of colors +($1,600) Assembly: Please assemble my chassis +($595.00)
If you go the fully optioned route, it adds up to $32,324.00. Thats a lot of coin for only marginal performance gain over what you can do to the stock system for $4000. Of course the Schwartz guys will spout off about their adjustablity and geometry changes and how that all is head and shoulders above stock stuff.
For your 70 Roadrunner, including vehicle purchase, restoration, and rebuild costs, and your classic could easily top $100k using the figures above.
[Re: PHJ426]
#1263271
07/07/12 10:33 PM
07/07/12 10:33 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Art Morrison has kits for Mopars too.
Mopar to the bone!!!
[Re: PHJ426]
#1263272
07/08/12 06:42 AM
07/08/12 06:42 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Actually you can buy a resto modded Mopar for about the same cash you would spend with this frame company. Here on Moparts in the 71 and up B body this car is available not mine and I dont know the guy that built it but here you go:
71 roadrunner srt 6.1 hemi conversion all of the goodies: alterkation TTI wilwood - all 4 corners Challenger SRT interior AC. Power windows 518 O.D. Build up is posted in member projects section of this board. Was featured in Jan 2012 Chrysler power magazine. ASKING $36k (you may be surprised what I may sell this car for....to the right person!) PM here or call 813 434 6668 thanks Dave
this car is sick - I would buy it!
[Re: dangina]
#1263273
07/08/12 05:18 PM
07/08/12 05:18 PM
PHJ426
Fly Over States
No doubt, anyone can have a new Challenger just sign here.............
That 71 Road Runner is a good looking ride!
[Re: PHJ426]
#1263274
07/08/12 07:48 PM
07/08/12 07:48 PM
"Your Mopar’s uni-body construction is inherently weak. Our G-Machine Chassis isn’t."
Wow, really!?
While in stock form it leaves a lot to be desired, I think I could spend $9k+ and have a uni-body that is more than up to the task!
[Re: Kern Dog]
#1263278
07/09/12 05:01 PM
07/09/12 05:01 PM
Posts: 20,755 A collage of whims
topside
A collage of whims
Like most all build vs. buy questions, the answer depends on these things: 1. Do you enjoy building cars? 2. Is the concept more important to you than the money? 3. Do you want to enjoy the end product now, or is the journey to get there part of your enjoyment? 4. Will you actually explore the limits 100% at the track, or is it a street car?
It's almost always less expensive to buy a finished project, like the '71 B mentioned, IF it's done right and it's to your taste. You need to set the goals & budget. I can appreciate the new stuff, but to me old cars are WAY cooler and usually a better investment. I've built enough cars to feel confident that I can do an early Camaro, Mustang, Challenger, etc that would equal the new models' performance for about the same money.
