Re: A-C Conversion Kits or.......
[Re: DusterJeff]
#1263247
07/06/12 09:50 PM
07/06/12 09:50 PM
RapidRobert
I see craigslist ads regularly for (1) to several individual cans of R12 for ~20 ea iirc. If you can buy several cans that way locally plus beg or borrow an R12 gauge set to get it into your system & your system is just a bit low with no other issues you might very well take care of the prob for cheap
[Re: Challenger 1]
#1263250
07/06/12 10:56 PM
07/06/12 10:56 PM
Posts: 3,051 Bowling Green, KY
cudaboy
Bowling Green, KY
R-12 is not hard to find. A buddy at work buys and sells it all the time. He finds 30lb sealed bottles for less than $300 all the time, as a matter of fact I picked up two for him a few weeks ago. As far as certification, you take an online test and pay $20. http://www.epatest.com/He has his, but is rarely asked when he buys. Dennis
[Re: DusterJeff]
#1263254
07/07/12 03:14 PM
07/07/12 03:14 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
I use the ES12a Industrial. It's hydrocarbon based and I'm sure some will about that, but in my black heat-absorbing Dakota it will flat out freeze you. When I first converted it, the center outlet temperature was 38 degrees on a 90 degree day, and that was idling in the driveway. 52 degree drop over ambient is pretty decent. I bought the 63lb equivelant cylinder for $180 with free shipping. I'm willing to deal with something flammable versus something that causes cancer. http://autorefrigerants.com/co00033.htm
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Challenger 1]
#1263255
07/08/12 10:23 AM
07/08/12 10:23 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Going to need new hoses and dryer either way
You nailed it on the head. With the cost of refrigerant being what it is today, how can anybody just dump in refrigerant without doing a leak detection first. The refrigerant didn't just magically "disappear".
[Re: Commando1]
#1263256
07/08/12 11:33 AM
07/08/12 11:33 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I really cant believe how many people actually buy into all the BS about r-12 conversions Just get one of those el-cheapo recharge kits from Advance or Autozone and make your cabin cool again. Don't believe all that BS about changing your drier,compressor,seals,etc... I have been a tech for over 30 years and have converted probably over 100 cars with 100% positive results without changing ANYTHING other than the freon Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: savoy64]
#1263257
07/08/12 11:33 AM
07/08/12 11:33 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
when my son converted my ramcharger all he had to do was screw in the fill adapter for the 134 system then fill it---the adapter looks like a hose fitting----doesnt cost much either---talk to one of the guys at a service station that handles AC units---bet he could set you up----bob
Unless the system already had oil compatible with both R-12 and R-134a (AB, alkylbenzene) it's a time bomb... the oil used with R-12 is not miscible in R-134a and your compressor is likely way under-lubricated.
The cheap "Death Kits" that have an oil charge too will often work for a while, but the two oils don't mix and the original oil is still "hiding" somewhere in the system, taking up space that should be used for refrigerant.
Also when changing oils, check for compressor seal compatibility as well as O-ring material. A proper conversion is not as simple as just sucking out the old refrigerant and putting the other one in...
Hydrocarbon (70% propane, 30% butane, or maybe it's the other way round) known as Duracool 12a and other brands works great and has zero ozone depleting potential. The people who make expensive, patented "Freon" have successfully lobbied and scared at least 17 US states into making it illegal for mobile a/c use. Never mind that it's extensively used in Oz and South America and the news is not full of stories with the cars blowing the windows out a la "Cheech & Chong". And the 2 lb of propane that dissipates in the breeze if a pipe is broken is far less a hazard than the 100+ lb of also explosive liquid hydrocarbons in the gas tank!
Anyway I've tried quite a few methods: proper conversion as detailed above; Duracool propane/butane; R-406a (R-12 drop-in approved "transitional" replacement, not sure if you can still get it); and $20 cans of R-12 in a tight system. They all seem to work about equally well.
