360 Magnum carburated intake options
#1263093
07/06/12 04:27 PM
07/06/12 04:27 PM
Posts: 2,096 mesa,az.
wedgepower
mesa,az.
I used the search function and came up with very little newer info on this subject. I'm putting together a 360 Magnum out of a '97 for my '75 4x4. I'm at the point where I need to make a decision on an intake. I want to retain good low end,so I'm thinking dual plane. MP and Edlebrocks are up towards the $300 range and that isn't going to happen. There are some off brands(Chinese I assume) that are $125-$200. I've heard they have some issues sealing. That about covers my new options. I haven't found much for used as I figure there just are a ton out there to begin with and what is out there is in use.
My other options are possible because I have access to a Bridgeport,tig,and a mad scientist named Bob Egli. The first is to redrill the heads and used an LA intake. Plenty of those used,I think I even have an old OFFY 360. My other option is to mill the top of the factory EFI manifold and weld a carb plenum/plate into it. Honestly,as far fetched as that idea is I like it the best. I think the long runners would give me some good bottom end and it would definetly be different. I like different. The biggest downfall to either of these ideas is that once I'm done redrilling the heads there is no going back,not that I would need to,I just like options. And if we build the EFI into carburated and it didn't work I'd be pulling the top end back off the drill the heads.
Any ideas?
Re: 360 Magnum carburated intake options
[Re: BulletBob]
#1263100
07/09/12 08:56 AM
07/09/12 08:56 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you could have the heads re-drilled to accept the LA intakes. it allows you to still use the magnum threads if you go back to a magnum intake later
**Photobucket sucks**
[Re: wedgepower]
#1263103
07/11/12 11:09 AM
07/11/12 11:09 AM
Posts: 597 West Newbury, MA
MOPAR_AMC_FAN
West Newbury, MA
To jump in on this post... So, if you go with the Crosswinds intake on the Magnum engine, you can run the regular V-belt setup instead of the serp belt? I read somewhere you just need to buy an earlier water pump for the Magnum engine to run a V-belt setup. True? Obviously, you'd have to use the pulleys and such off a V-belt motor, too. Any other issues or anything?
Looking to carb a Magnum 360, but want to run V-belts instead of the serp belt. Oh, I'd be running A/C, too, if that matters.
