Hemi plug lead suggestions required #1262504
07/06/12 01:34 AM
07/06/12 01:34 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I'm looking for a couple of sets of plug leads for my early '70s Pro Stock style dual plug Hemi. Can a guy buy a reasonable set of say 8mm leads these days without them having the book of War & Peace printed down their entire length?
A couple of sets of plain black/colored leads that I could cut to fit would be great . . any suggestions?
Re: Plug lead suggestions required [Re: nz383man] #1262505
07/06/12 02:56 AM
07/06/12 02:56 AM
MSD use to offer them in red and black with the porclyn insulators included, that was a couple of years ago. Moroso may also offer them in black, my last choice would be Jacobs unassembled sets with insulators, cut to fit the distributor ends
Re: Plug lead suggestions required [Re: Cab_Burge] #1262506
07/06/12 07:34 AM
07/06/12 07:34 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Might take a look at rick from Firecore products.His username is sunroofgtx
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Plug lead suggestions required [Re: hemi-itis] #1262507
07/06/12 11:35 AM
07/06/12 11:35 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i just got a set from Rick. best set of wires i ever bought. hemi wires are a little pricey, but worth it. took care of the high rpm miss i had.
Re: Plug lead suggestions required [Re: rickraw] #1262508
07/06/12 04:07 PM
07/06/12 04:07 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Get on ebay and look for old Acell wires from that era.
2011 Drag Pak Challenger
Re: Plug lead suggestions required [Re: rickseeman] #1262509
07/06/12 04:08 PM
07/06/12 04:08 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I have a set of NOS Pro Stock D-5 heads and nice rockers if you need them.
Re: Plug lead suggestions required [Re: rickseeman] #1262510
07/06/12 04:09 PM
07/06/12 04:09 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Be advised it takes 3 sets of plug wires.
Re: Plug lead suggestions required [Re: rickseeman] #1262511
07/06/12 06:29 PM
07/06/12 06:29 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Thanks for the input Guys.
Can you explain this a bit more plesae, I was thinking that the wire would be long enough to fit & I'm using a right angle dual dizzy so mabe I would swap the longer wires from left to right.
Re: Plug lead suggestions required [Re: nz383man] #1262512
07/08/12 11:56 PM
07/08/12 11:56 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I made a set for, RIP, Dick Towers. Came out nice. We lost our supplier for the original Heemi Tubes. If you have 16of them, I'll make you the set in either black, or the higher-priced orange. I have a pic of a dual plug we did. Can't find it, though. Do you have the lengths already?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Plug lead suggestions required [Re: sunroofgtx] #1262513
07/09/12 04:10 AM
07/09/12 04:10 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Thanks for your reply, all I have for my leads so far is 16 of these
I don't have the lengths yet but i have just finished the right angle dual dizzy so i should be able to sort out the lengths soon.
Re: Plug lead suggestions required [Re: nz383man] #1262514
07/09/12 12:54 PM
07/09/12 12:54 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Ours but has covers over the wires
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Plug lead suggestions required [Re: toplescuda] #1262515
07/09/12 12:55 PM
07/09/12 12:55 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Side shot
1971 charger
Re: Plug lead suggestions required [Re: toplescuda] #1262516
07/10/12 03:14 AM
07/10/12 03:14 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Those wires look quite thick, what size are they?
What brand and do they have writing all the way along them or are they plain red?
Cheers.
Re: Plug lead suggestions required [Re: nz383man] #1262517
07/10/12 01:53 PM
07/10/12 01:53 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
There moroso wires with a nylon cover on them that you can get from jegs/summit
if you can zoom in enuff you can see red ele. Tape on ends by the cap
the sleeve spossed to keep from crossfiring
there is no writing on them but each has numbered tag so if took off can go right back in same place(also from jegs/summit)
1971 charger
