Re: E-body K-frame in a 67 B-body?
[Re: JohnRR]
#126246
09/27/08 08:17 AM
09/27/08 08:17 AM
HOTHEMI
14437
[Re: JohnRR]
#126247
09/27/08 09:47 AM
09/27/08 09:47 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
It will bolt on but the steering box anle is different . Will it work like that ????
Sway bar is also different. If you want one of those you'll need the E-body bar and LCAs.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: JohnRR]
#126248
09/27/08 11:06 AM
09/27/08 11:06 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
It will still work in a 70 B-body with the slight angle diff. IMHO, it will work in a 67. And you get a more common idler arm.
IIRC, 67 B-body has a stud type idler like the 67 A-bodies.
[Re: autoxcuda]
#126249
09/27/08 12:35 PM
09/27/08 12:35 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
It will bolt on but the steering box angle is different . Will it work like that ????
Yes it uses the stud mounted idler and last time I checked it's still available .
the swaybar issue is trival compared to the steering box angle , drill 4 holes and the 67 swaybar will work fine .
