radio went dead... #1262406
07/05/12 08:58 PM
07/05/12 08:58 PM
Cincinnati Ohio USA
Moeggenpar Offline OP
Cincinnati Ohio USA
the radio in my 94' Acclaim suddenly stopped working.The fuse checks out OK,maybe a grounding issue? Thanks for any info
Re: radio went dead... [Re: Moeggenpar] #1262407
07/06/12 02:03 AM
07/06/12 02:03 AM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
I had that happen on my 99 Ram, turns out it is the positive fed o the radio which also powers my OBC port. On the Ram they are a pink wire. Did not find the where the break in the wire was. I had to run a jumper to power the OBC port for it to pass emission test here in AZ. Ran a different wire to power the radio.
Still Broke
