Did I screw up??? Help with timing *DELETED* #1262358
07/05/12 08:09 PM
07/05/12 08:09 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Post deleted by Alexdodge
Re: Did I screw up??? Help with timing [Re: Alexdodge] #1262359
07/05/12 08:19 PM
07/05/12 08:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
turn the engine over until the damper is at TDC...does the rotor point at number 6...if so..just remove distributor and reset it pointing at number 1.
Tony
70 AARCuda Vitamin C
Re: Did I screw up??? Help with timing [Re: 70AARcuda] #1262360
07/05/12 08:21 PM
07/05/12 08:21 PM
Eastern ohio
Eastern ohio
I'll go try that now thanks
Re: Did I screw up??? Help with timing [Re: Alexdodge] #1262361
07/05/12 09:47 PM
07/05/12 09:47 PM
I believe the piston is not actually near TDC. If it was the timing marks on the dampener/timing tab would be within a degree or 2 of TDC unless the dampener has slipped and not likely for that to have happened. try again bumping the starter relay with a screwdriver while you hold your thumb over the #1 plug hole till you feel it pushing on your thumb AND the marks are getting close to TDC. Then continue to turn it clockwise till the marks are at 10 BTDC (mild cam) or 15 BTDC (wild cam) then line up the dist pickup magnet dead even with the reluctor tooth that places the rotor under the #1 plug wire location in the cap and the vac adv can in it's general correct location with room to be turned either way
Re: Did I screw up??? Help with timing [Re: Alexdodge] #1262362
07/05/12 09:52 PM
07/05/12 09:52 PM
places
79powerwagon Offline
places
Stop using the starter and put a wrench on it instead.
Re: Did I screw up??? Help with timing [Re: 79powerwagon] #1262363
07/05/12 11:19 PM
07/05/12 11:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
more then likely went you aligned the dots on the cam/crank sprockets...you had the cam dot a 6 o'clock and the crank at 12 o'clock.. and then you installed the distributor...at the point the engine is on number 6 firing...remove distributor and rotate 180....pretty simple...10 minute job.
Tony
Re: Did I screw up??? Help with timing [Re: 79powerwagon] #1262364
07/05/12 11:27 PM
07/05/12 11:27 PM
Eastern ohio
Eastern ohio
I rolled the engine over again till it pushed my thumb off the plug hole and it still came up 180 out.I then rolled the motor over so the timing marks on the cover and on the damper match up. Then set the distributor so the rotor is looking at the number 1 plug. Won't be able to fire it up until tomorrow morning. Parts store gave my wrong plug wires.
Hope I did this the way you guys meant to do. Thanks guys!!!!
Re: Did I screw up??? Help with timing [Re: Alexdodge] #1262365
07/06/12 08:46 AM
07/06/12 08:46 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Small block big block??
Re: Did I screw up??? Help with timing [Re: Dodgem] #1262366
07/06/12 11:44 AM
07/06/12 11:44 AM
Eastern ohio
Eastern ohio
Big block. Problem solved thanks all!
Re: Did I screw up??? Help with timing [Re: Alexdodge] #1262367
07/06/12 12:41 PM
07/06/12 12:41 PM
what did you do that fixed it?
