Holley 750 ?? #1262020
07/05/12 10:12 AM
07/05/12 10:12 AM
GoDartGo Offline OP
GoDartGo  Offline OP
I'm new to the 750 DP.
So, what is the vac port for, that is on the front metering block
on the choke side just above the idle screw?
I am "testing" a friends 750 who got it from a guy who got it
from...............I might buy it.
Re: Holley 750 ?? [Re: GoDartGo] #1262021
07/05/12 10:13 AM
07/05/12 10:13 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
distributor advance?
Re: Holley 750 ?? [Re: 05dakota] #1262022
07/05/12 10:14 AM
07/05/12 10:14 AM
GoDartGo Offline OP
GoDartGo  Offline OP
I believe that is on the base plate.
Re: Holley 750 ?? [Re: GoDartGo] #1262023
07/05/12 11:38 AM
07/05/12 11:38 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
The vac port on the metering block is a "ported vacuum" source. It is where the Mopar brand vacuum advance distributors are supposed to be hooked to.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Holley 750 ?? [Re: bigsbigelow] #1262024
07/05/12 01:44 PM
07/05/12 01:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you hook it up to a vacume port on the carb. that is using intake manifold vacume you will have full vacume advance at idle and loose it at WOT GM did that way for a short while in the 1950s on the V8 Chevys
Re: Holley 750 ?? [Re: Cab_Burge] #1262025
07/05/12 02:07 PM
07/05/12 02:07 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
if you hook up to manifold vacuum that might not be a bad thing. mopar distributors are horribly over advanced from the factory anyway. you really want to get some lighter springs in there and if you hook up to manifold vacuum you will have your base advance plus canister advance giving you around 15-16 degrees which is good. the while driving you get your base advance plus your plate advance which would put it around 35 degrees
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
