distributor parts #1261712
07/04/12 02:13 PM
07/04/12 02:13 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
does anyone know where to buy the triangle shaped spring clip that holds breaker plate inside the old mopar distributors? Still runnin points on my resto mopars and need a few of these that are new, as mine has lost tension and lets plate move to much. thanks fellas
If I hafta come in and getchya.......I'm gonna getchya!
Re: distributor parts [Re: Gt383] #1261713
07/04/12 07:00 PM
07/04/12 07:00 PM
I dont think anyone makes them. I'd pirate one off of a junk dist. Those I've seen hold their tension pretty good. I'd make sure the problem is that rather than something wearing down on the point plate EDIT the pin could be worn and or the hole in the plate could be wallowed out
