Clutch/Brake pedal bushings? #1261629
07/04/12 03:06 AM
07/04/12 03:06 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
I have had no luck finding the larger brake pedal pivot bushings for my pedals. I have the small shaft a-body pedals, clutch pivot is 1/2" I can get those at brewers but there are two larger bushings for the brake pedal and I can't find a manufacturer that makes anything in either bronze or nylon. I'd like to just find some in brass/bronze and be done. Can anyone make them or know where I can purchase them? Thanks
Re: Clutch/Brake pedal bushings? [Re: rck850] #1261630
07/04/12 04:52 PM
07/04/12 04:52 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
