FWD transmission GURU's! 1999 caravan question! #1261556
07/04/12 12:29 AM
07/04/12 12:29 AM
North Central Florida
E
eightlitermopar Offline OP
E
Long story short, I got a 1999 Dodge Caravan with the 3.3 motor, 4 speed overdrive automatic. Only 88,000 miles.
I got a deal because the transmission is giving them problems.
Put the tranny in Drive, and it goes 1st and 2nd gear, but no shift into third or overdrive. The short drive home seemed to start in 2nd and stay there, but another test around the neighborhood confirmed that it is shifting.
The original owner says:
1) the transmission was replaced under warranty once already a few years ago.
2) The recent OBD readout (which he does not have currently) says no third or fourth gear.
This is all he knows.
Anyway, I was thinking of changing transmission fluid and filter, and replacing the 2 speed sensors on the transmission just to see what happens.
For those of you with experience here, what do you think?
If I have to replace the entire transmission, I am still getting this van for way less than Blue book, so it’s a win to me.
Your thoughts?
Eightlitermopar
Mopar or no car
Re: FWD transmission GURU's! 1999 caravan question! [Re: eightlitermopar] #1261557
07/04/12 12:56 AM
07/04/12 12:56 AM
ill
dennismopar73 Offline
ill
I would look at the electric part, ie wiring.
possable tranny pc??
check the input /output sensors, look for debre(junk)(trash) on them,
Re: FWD transmission GURU's! 1999 caravan question! [Re: dennismopar73] #1261558
07/04/12 07:08 PM
07/04/12 07:08 PM
E
E
Thanks for the reply;
Just for "fun", I changed the filter and fluid today. It looked ok, but the magnet was quite "furry". I will post some pics later.
Auto zone codes are p0733 and p0700.
I am thinking it is electrical.
It will shift: 1st, 2nd, and then hesitate like in neutral, then go to third or "limp mode" gear.
I am thinking TCM or speed sensors. Does anyone have any recommendations where to buy TCM's ?
Eightlitermopar
Mopar or no car
Re: FWD transmission GURU's! 1999 caravan question! [Re: eightlitermopar] #1261559
07/04/12 07:14 PM
07/04/12 07:14 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
The input and output speed sensors maybe?
Re: FWD transmission GURU's! 1999 caravan question! [Re: Tom Hand] #1261560
07/04/12 07:47 PM
07/04/12 07:47 PM
Oahu, Hawaii
P
ParadiseCuda Offline
P
Oahu, Hawaii
Best thing to do is take it to a transmission shop and have them read the codes and then replace the faulty part. I had the same issue with my 94 caravan and it was the valve pack. One of the valves was not working properly and it would put the transmission into the limp mode, 1st and 2nd only.
Re: FWD transmission GURU's! 1999 caravan question! [Re: ParadiseCuda] #1261561
07/04/12 08:52 PM
07/04/12 08:52 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
If it shifts 1-2 then does a 2-neutral shift its probably a broken o/d clutch drive hub or a stipped out planetary gearset. Internal problem, trans has to come out.
Re: FWD transmission GURU's! 1999 caravan question! [Re: eightlitermopar] #1261562
07/04/12 11:41 PM
07/04/12 11:41 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
IIRC "limp in mode" - will start and stay in 2ND gear.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: FWD transmission GURU's! 1999 caravan question! [Re: Evil Spirit] #1261563
07/05/12 02:02 AM
07/05/12 02:02 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I just replaced the solenoid pack on mine yesterday and i think it had the same codes one was shift solenoid b and electronic shift malfuntion , get somebody with a better code scanner to make suremine just stopped shifting into overdrive that fixed it the part no te6 got it from rock auto it was $107 bucks advanced was a $180 for it,
Re: FWD transmission GURU's! 1999 caravan question! [Re: teflon] #1261564
07/05/12 02:46 AM
07/05/12 02:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep that is most likely the problem. Seen it many times over the years. But do check codes as it might just give a Speed ratio Error code. Ron
Re: FWD transmission GURU's! 1999 caravan question! [Re: eightlitermopar] #1261565
07/05/12 06:02 PM
07/05/12 06:02 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My sister's van had a similar problem. Swapping out the solenoid pack and the wire plugs fixed the issue. It was a quick and painless job.
- Stu Harmon
Re: FWD transmission GURU's! 1999 caravan question! [Re: feets] #1261566
07/05/12 07:24 PM
07/05/12 07:24 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Also check all of the ground straps. Poor grounding causes issues with these transmissions.
BTW, what fluid did you put back in it?
A friend has a 2004 and all of a sudden he had transmission problems. I asked if he had it serviced recently and he confirmed that the shop changed the fluid but didn't note what kind of fluid they used. They probably put the wrong fluid in.
Use ATF+4.
Re: FWD transmission GURU's! 1999 caravan question! [Re: NicksGarage] #1261567
07/06/12 09:03 PM
07/06/12 09:03 PM
E
E
I put ATF + 4 in, but it won't matter.
I took it to the shop today, internal issues so they will be disecting it on monday. Most likely cost 2500 bucks or more. I got the van for a steal though, so I was expecting it.
So here is my updated question. What causes all these dodge minivan trannies to fail like this?
Poor design? High heat? Poor pump? Soccer mom driving? It seems that a transmission SHOULD last more that 80K miles.
What can I do to get a little more mileage out of something like this?
Thanks guys! I know this topic isn't as exciting as transbrakes or hemi stroker motors....
Eightlitermopar
Mopar or no car
Re: FWD transmission GURU's! 1999 caravan question! [Re: eightlitermopar] #1261568
07/07/12 11:02 AM
07/07/12 11:02 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
It stripped the splines from the front planet or broke the overdrive hub.They make an updated overdrive hub that is larger diameter and a forward planet with hardened splines.
Re: FWD transmission GURU's! 1999 caravan question! [Re: eightlitermopar] #1261569
07/07/12 02:06 PM
07/07/12 02:06 PM
Canada's West Coast
Graham Offline
Graham  Offline
Canada's West Coast
Solenoid pack, input output speed sensors problems
The main reason for planetary failure, too many owners thought they could tow with this vehicle.
Re: FWD transmission GURU's! 1999 caravan question! [Re: Graham] #1261570
07/08/12 01:13 PM
07/08/12 01:13 PM
E
E
I don't plan on towing with this van, and if it doesn't already have an auxillary cooler, I will be putting one on.
However, I know that wouldn't save internal drums and splines
eightlitermopar
Mopar or no car
