Headliner Q #1261510
07/03/12 11:21 PM
07/03/12 11:21 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
I've got a new headliner and glue on order for the Dart. Is there anything else I need?
It has been too long, but for the sides of the headliner all that holds it in place is the adhesive and then the aluminum trim (which has spring clips on the back), correct? The front and rear is held via the teeth in the sheet metal.
383, Hemi 4-Speed, AlterKtion, D60
Re: Headliner Q [Re: Crazy68Dart] #1261511
07/03/12 11:45 PM
07/03/12 11:45 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
those big springy paper clips you get at staples can be a big help and don't forget a hairdryer.
