v6 intakes where to buy #1261227
07/03/12 02:59 AM
07/03/12 02:59 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
i dont even know if such a thing exists but id like to find a v6 magnum intake that allows me to run a carb
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: v6 intakes where to buy [Re: gogo318] #1261228
07/03/12 12:42 PM
07/03/12 12:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I don't think you're going to find that.
What are you trying to do?
- Stu Harmon
Re: v6 intakes where to buy [Re: gogo318] #1261229
07/03/12 01:09 PM
07/03/12 01:09 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I think there WERE carb intakes made...and quite possibly for the magnum headed engines. Mopar Performance issued some 3.9 v6 crate engines iirc, and they used a dual plane mopar intake for carbs...iirc, not many were made so tracking them down is near impossible.
they may have been for the LA style heads too, so redrilling/tapping for LA style bolt pattern is a possibility too.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: v6 intakes where to buy [Re: Prince_Valiant] #1261230
07/03/12 02:37 PM
07/03/12 02:37 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
mopar used to make a 4bbl. intake for the 3.9 its been discontinued for a long time. i had one on my 87 dakota. they were for the LA style intake bolts, not the magnum. you can find 2bbl. intakes on dakotas in the junkyard, also for LA style heads.
Re: v6 intakes where to buy [Re: feets] #1261231
07/03/12 08:37 PM
07/03/12 08:37 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
after a lil investigation (removing the throttle body)i found the bolt hole arangement and bores are just like older two barrels that can be found on most all stock 318 the pattern is a tad bigger than the 80s carter and holley factory twos and bigger still than the late 60s stromberg twos but i dont have my 4x4 truck here to refrence but i remember the pattern to be larger than the afore mentioned carbs maybe.....just maybe it would bolt right on ! then i just have to figure out what to do about the distributor ............ill let you guys know what i come up with!
Re: v6 intakes where to buy [Re: gogo318] #1261232
07/03/12 10:20 PM
07/03/12 10:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
LA distributor with a /6 reluctor will net you an V6 electronic distributor with mechanical and vacuum advance.
Don't be the exception.
