Hmmm...Something is going on here....
#1261196
07/03/12 02:21 AM
07/03/12 02:21 AM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Re: Hmmm...Something is going on here....
[Re: mikeysmopars]
#1261198
07/03/12 02:40 AM
07/03/12 02:40 AM
Posts: 5,875 communist bloc of new jersey
jamesc
yea you're runnin out of space.
what did you have to do to use the GM quick release on the chrysler steering shaft? didn't want to start filing till i knew if i was doing the right thing. don't want to hack something up if it won't work than not be able to return it cause i hacked it.
[Re: Al_Alguire]
#1261209
07/03/12 10:12 AM
07/03/12 10:12 AM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
That's what happens when you park a male barracuda that close to a female barracuda. Should of had one of them fixed.
[Re: Al_Alguire]
#1261212
07/03/12 11:46 AM
07/03/12 11:46 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Wll the big issue right now is what to do with this new addition. What direction to take it in that is
Paint it the same colors as the other two
[Re: Moparnut426]
#1261214
07/03/12 12:36 PM
07/03/12 12:36 PM
Triple Threat
Renton Washington
I think a good 10.50 street strip bracket car for Steven to race. Sort of like my car, but a little faster. Good for Pro, Super pro, super street, open comp, does PSCA have a 10.50 index class?
[Re: Moparnut426]
#1261215
07/03/12 12:36 PM
07/03/12 12:36 PM
Al_Alguire
Las Vegas
James to answer your question the one I used simply bolted roight on the stock column.
As for the car. Since it is a numbers matching Formula S 383 4 Spd car I think we will not get to crazy or carried away. Although it already has some modifications that require some work to undo if it is to be restored someday. Thinking a Pro Touring kinda set up sounds fun though. Nothing to crazy.
