My 37 Dodge pickup has a 88 Dakota front end under it. I had to alter the supply and return lines from the pump for the rack. The lines have different threads to the rack. I may have put the wrong end on my supply line. What I need to know is which hole in the rack is the supply hole, Top or bottom hole? The rack is not marked. I sure hope some one can help me out?
Thanks for the post, Tony
etony58@gmail.com
