Re: Staggered front end?
[Re: '72CudaRacer]
#1261036
07/02/12 10:04 PM
07/02/12 10:04 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
how much of a stagger is there? i would think trimming a strut bushing would be easiest and cheapest
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: '72CudaRacer]
#1261037
07/02/12 10:38 PM
07/02/12 10:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If the stagger was built into the front end at a chassis shop they moved the one side back(most likely the pass side)... if this is what was truly done then your gonna have to cut the mount points on that side... if you try to do it with the alignment it will pull... if you want to speed up the RT then put smaller front tires on it
[Re: sixpackgut]
#1261038
07/02/12 10:48 PM
07/02/12 10:48 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Close to an inch.
[Re: MR_P_BODY]
#1261040
07/02/12 10:58 PM
07/02/12 10:58 PM
'72CudaRacer
Mooresburg, Tn
I can't put smaller tires on with out changing the oil pan. The pan doesn't hit when the wheels come down, just on uneven pit areas.
As far as HOW it got staggered, This car was wrecked when I rescued it from the back row of a note toter car lot. After changeing ALL of the front sheet metal, I had to have the front frame section pulled at a body shop. After all of this, I had it on a alignment rack and the front was staggered. Perfect, leave it like it is. (this was 1984, the going thing back then) Now I want to take the stagger out, and I'm not sure what is the best way to do it.
Brian Dunnigan
[Re: moparguy7074]
#1261041
07/02/12 11:00 PM
07/02/12 11:00 PM
'72CudaRacer
Mooresburg, Tn
How is it staggered? Is the k-member moved?
I'm not sure really how to tell. I think it may be the struts, one of them may be bent slightly?
Brian
[Re: rowin4]
#1261044
07/02/12 11:23 PM
07/02/12 11:23 PM
MR_P_BODY
Pull the frame into spec.
Yep... finish pulling the one side...without cutting the pivot points off you dont have many choices... I stagger my chassis cars... mine has 3/4" but I use small tires and the stagger keeps me in the lights a bit longer..... Or make a new oil pan with wings
