1967 RO/WO Carb Cfm? #1260902
07/02/12 04:29 PM
07/02/12 04:29 PM
WI
ThunderLugs Offline OP
WI
I am curious as to what was the cfm of the carter carbs used on the 67 Dodge and Plymouth WO & RO Hemi's ?
Re: 1967 RO/WO Carb Cfm? [Re: ThunderLugs] #1260903
07/02/12 04:32 PM
07/02/12 04:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 1967 RO/WO Carb Cfm? [Re: JohnRR] #1260904
07/02/12 05:28 PM
07/02/12 05:28 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Same carbs as 67 Street Hemis 625 (each) 4139s&4140s
Re: 1967 RO/WO Carb Cfm? [Re: ScottSmith_Harms] #1260905
07/02/12 06:18 PM
07/02/12 06:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Scott I thought they got the "CHEATER" carbs ?
Re: 1967 RO/WO Carb Cfm? [Re: JohnRR] #1260906
07/02/12 07:08 PM
07/02/12 07:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nope, thats bad info. The 750 (manual choke) carbs never came on them off the production line, some racers used them hoping to not get caught (hence the term "cheater carbs") but they are not correct for an "as delivered" factory restored car.
Re: 1967 RO/WO Carb Cfm? [Re: ScottSmith_Harms] #1260907
07/03/12 10:17 AM
07/03/12 10:17 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Now who's ?
Re: 1967 RO/WO Carb Cfm? [Re: Commando1] #1260908
07/03/12 10:33 AM
07/03/12 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I am spanking me ...
Re: 1967 RO/WO Carb Cfm? [Re: JohnRR] #1260909
07/03/12 11:12 AM
07/03/12 11:12 AM
500CIB1 Offline
500CIB1  Offline
could you tell me what the part numbers are for the 750 carbs.also are the fuel lines on the same side.i have a lead on a pair of 750's not sure of the numbers.thanks mark
Re: 1967 RO/WO Carb Cfm? [Re: 500CIB1] #1260910
07/03/12 11:26 AM
07/03/12 11:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
4345S front , 4346S rear , fuel lines would be on the same side , right side .
Re: 1967 RO/WO Carb Cfm? [Re: JohnRR] #1260911
07/03/12 11:34 AM
07/03/12 11:34 AM
500CIB1 Offline
500CIB1  Offline
thanks the carbs i found have no chokes and fuel inlet on the other side part number 4762s
Re: 1967 RO/WO Carb Cfm? [Re: 500CIB1] #1260912
07/03/12 12:48 PM
07/03/12 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
fuel inlet on the other side was a Ford and/or GM thing .
