vibration damper balance/torque converter #1260869
07/02/12 02:50 PM
07/02/12 02:50 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
On a 318 Cuda made in 3/73 was the crank cast or forged steel? Are they both internally balanced? Should the torque converter have weights on it when viewing it from the inspection plate if I turn the motor over with a wrench?
Re: vibration damper balance/torque converter [Re: tcat446] #1260870
07/02/12 03:03 PM
07/02/12 03:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
318 was cast crank , at least 70 up , not sure about truck motors of certain years , they are all internal balanced so you shouldn't find weights on the converter or a weighted dampner.
