how to identify 742 or 489 aluminum case for rear end #1260851
07/02/12 02:27 PM
07/02/12 02:27 PM
440dustr Offline OP
440dustr  Offline OP
I have had an aluminum case for my mopar 8-3/4 rear. I thought it was a 489 case but how do I know for sure. I bought richmond gears 3.55 and eaton detroit truetrac with new richmond bearing kit all for a 489. but it looks like the front pinion gear bearing is to small that came with the kit.
the aluminum center section has no numbers on it to go by.
if I have all 489 stuff I assume it wont fit a 742 case is that correct?
thanks
Re: how to identify 742 or 489 aluminum case for rear end [Re: 440dustr] #1260852
07/02/12 03:05 PM
07/02/12 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The MP alum case was only ever made for 742 gears .
Re: how to identify 742 or 489 aluminum case for rear end [Re: JohnRR] #1260853
07/03/12 11:57 AM
07/03/12 11:57 AM
440dustr Offline OP
440dustr  Offline OP
who else makes an aluminum case besides MP
the one I have doesnt have the bolts go through the houseing just the 2 bolt on the end caps like a normal carrier.
Ill have to go take a picture of mine maybe someone has seen this before.
Re: how to identify 742 or 489 aluminum case for rear end [Re: 440dustr] #1260854
07/03/12 12:03 PM
07/03/12 12:03 PM
iowa
copchaser Offline
copchaser  Offline
iowa
Mickey Thomson made them years ago also, I'm thinking there were 742 also.
Re: how to identify 742 or 489 aluminum case for rear end [Re: copchaser] #1260855
07/03/12 12:06 PM
07/03/12 12:06 PM
dogdays Offline
dogdays  Offline
That part belongs in the Smithsonian!
R.
Re: how to identify 742 or 489 aluminum case for rear end [Re: 440dustr] #1260856
07/03/12 12:46 PM
07/03/12 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know anyone else made one , is it aluminum or magnesium ?
Re: how to identify 742 or 489 aluminum case for rear end [Re: JohnRR] #1260857
07/03/12 02:29 PM
07/03/12 02:29 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
E-berg had a magnesium M/T case in the Green Brick for a while.
Re: how to identify 742 or 489 aluminum case for rear end [Re: 440dustr] #1260858
07/23/12 01:53 PM
07/23/12 01:53 PM
440dustr Offline OP
440dustr  Offline OP
I just got my centersection back I was told the aluminum houseing was made by stange and that the bearing I needed was used with a ford 9" heavy duty. Ill post of picture of the center section soon
Re: how to identify 742 or 489 aluminum case for rear end [Re: 440dustr] #1260859
07/24/12 11:56 AM
07/24/12 11:56 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This I believe is a Mark Williams Alum 8.75, along side a MP, might want to notice the thickness of the MW mounting flange, it is stout, and not for sale.
Re: how to identify 742 or 489 aluminum case for rear end [Re: jcc] #1260860
07/24/12 01:33 PM
07/24/12 01:33 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
There was time(1960s-early '70's) when a lot of dragsters used 8 3/4's and cases were made out of different materials.. I would guess they were all 742 cases because the pinion isn't tapered, which is the weak link of a 489.
Re: how to identify 742 or 489 aluminum case for rear end [Re: 52savoy] #1260861
07/24/12 02:52 PM
07/24/12 02:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The weak link isn't the taper so much as it is the crush sleeve that can get loose with repeated hard usage. A solid shim replacement setup will cure that.
Don't be the exception.
Re: how to identify 742 or 489 aluminum case for rear end [Re: Supercuda] #1260862
07/24/12 03:07 PM
07/24/12 03:07 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
what's all involved in installing the "crush sleeve" elliminator kit?
shouldn't all cases be stamped or numbered?
Re: how to identify 742 or 489 aluminum case for rear end [Re: Supercuda] #1260863
07/24/12 07:26 PM
07/24/12 07:26 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I'll stick by my comment unless someone can prove me wrong..
The spacer is one of two weak links on a 489,not counting ring gear diameter or deflection. 742's have(or used to) a much larger gear choice because of their strength(pin.stem diameter). Chrysler's "Performance Parts" pro gears were for a 742 case for a reason.
your turn..
Re: how to identify 742 or 489 aluminum case for rear end [Re: 52savoy] #1260864
07/24/12 11:14 PM
07/24/12 11:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Why would a tapered pinion be weaker than a big step in the pinon? Both designs neck down to the same OD in the front.
Here are side by side pictures:
http://www.moparts.org/Tech/Archive/axle/1.html
Re: how to identify 742 or 489 aluminum case for rear end [Re: 52savoy] #1260865
07/24/12 11:39 PM
07/24/12 11:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
your turn..
What?
The 489's pinion is thicker than the 742's in most of it's length and the same in the rest. Therefore, by your reasoning the 489 should be stronger.
You can believe whatever you want doesn't make it right.
Re: how to identify 742 or 489 aluminum case for rear end [Re: Supercuda] #1260866
07/25/12 05:18 AM
07/25/12 05:18 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
What ???? Removing metal doesn't make the stem stronger unless you've found out about some Area51 process that defies logic and.....metal..
The pinion is called "tapered for a reason. At just one point(1 7/8") is it bigger than a 742(1 3/4"). A 742 is straight cut to the yoke, just slightly smaller dia. than a 489 and therefore stronger. Now if Chrysler in hindsight decided to make the 1 7/8" machined straight all way over to the yoke we would have something.
Anyone can believe what they want but facts ARE FACTS.
Been doing this mopar thing going on 50 years so I don't need to make it up... and I doubt under any circumstances that I could convince you but no problem. If you make it my way some time I'll start up the grille and we'll go my shop to sort it out while the Texas BBQ is smoking..
comparison shot..... web page
I remember in the 70s Chrysler started getting negative feedback from racers who were breaking the large stem pinions in half. They put out bulletins on that subject and recommended racers use the non-tapered 742 case. The story is in the mopar bible. I happened to have worked for local stock and super/stock racers Starkey and Christian and their expierience went back to 1959. Even though I knew of Chrysler's position, it was the first time I got it from racers but with more details...
but it's ok... do your own thing or go Dana.
Re: how to identify 742 or 489 aluminum case for rear end [Re: 52savoy] #1260867
07/25/12 09:56 AM
07/25/12 09:56 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Regarding strength of 742 vs 489 stem, if someone could PROVE to me that it fails more then say once in a million, I'll join the argument of arraigning the deck chairs on the Titanic.
My suggestion, argue something more worthy.
Re: how to identify 742 or 489 aluminum case for rear end [Re: jcc] #1260868
07/25/12 10:12 AM
07/25/12 10:12 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I agree. Both designs have a square "stress riser" just inboard of the front bearing journal. The pinion diameter is overkill anyway. The weak link is ring gear size.
