Re: Cal tracs VS. Superstock springs
[Re: shoebox]
#1260758
07/02/12 12:38 PM
07/02/12 12:38 PM
Posts: 1,178 Indy
FlyFish
Indy
I went from stock springs (not super stock) to Caltrac mono's. The Caltrac mono's are ~25#'s a piece if I recall correctly, and my stock springs were ~ 35#'s each...so I cut 20#'s off.
The super stock springs are heavier than stock springs, so the weight savings is substantial.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1260759
07/02/12 01:12 PM
07/02/12 01:12 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If you're considering both.... its a no brainer, go Calvert. They're lighter & they're adjustable.
[Re: shoebox]
#1260760
07/02/12 01:38 PM
07/02/12 01:38 PM
Thumperdart
State of confusion
Calvert for us slow guys and never look back...........
[Re: shoebox]
#1260764
07/02/12 03:37 PM
07/02/12 03:37 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I see the thump and cars like that-looking good!!! But the old school Guys doing 1.30s on SS sure do get it done!!
Yep, i aint the smartest guy by far, but i had zero problems(after some minor tinkering) getting my 3350 pound s/s spring car with cheap 3 way shocks to hook anywhere and go mid 1.3xxx all the time, in the high 9's with very small 28 by 10 tires.
I say that because over the years i read thread after thread of caltrack posts where guys have a problem hooking, or should i try this or that, just to run high 9 's or slower. I find it kinda funny.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1260765
07/02/12 03:44 PM
07/02/12 03:44 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
On an A body, read short front segment, the Cal Tracs are not as effective as when the are used on a longer front segment car. The B & E bodies as well as most Fords respond well to them over a regular leaf spring assembly.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#1260766
07/02/12 04:44 PM
07/02/12 04:44 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Go Cal Tracs & Split Mono's & don't look back. If you are like the rest of us you will continue to go faster & faster & will eventually over power the S.S. springs. I have never seen any s.s. spring cars knocking on the door of 6 sec 1/4 mile e.t.'s. There are numerous Caltrac cars getting closer every day. In fact someone somewhere may have already done it. If you eventually go fast enough an anti-roll bar will help alot as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: fullmetaljacket]
#1260768
07/02/12 06:36 PM
07/02/12 06:36 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
There is a big price Difference, one reason i went with the SS springs, pick them up new/used for 175.00, and first time out on not a good track went 1.54 sixty
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Wedgeman]
#1260770
07/02/12 07:17 PM
07/02/12 07:17 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
How the hell do you go in the 1.30's with SS springs ? I cannot get decent numbers with mine !
Dan
With a LOT of work!
The front end is more important than the rear end in most cases.
