Type F or Dexron? And WHY??? #1260425
07/01/12 07:18 PM
07/01/12 07:18 PM
Renton Wa
topfueldart Offline OP
Renton Wa
Title pretty much covers it. I know there have been debates on this a hundred times, but I've never heard anything definitive as to why some people prefer type F over the standard Dex/Merc, other than the standard "ive used it for 20 years without issue" response. My entire trans/converter is new, so before just pouring fluid into it I thought id look for opinions. Ive always run the cheapest Parts Master Dex/Merc and havent had any issues, but dont expect I would have with Type F either.
My combo:
9.5 in PTC with Steel Stator
5 Pinion Steel Front Planetary
4 Pinion Rear
Billet Steel Front Drum with bleed hole for Brake
Ultimate Sprag
A&A Clean Neutral Transbrake
6/6 Clutch Packs with Alto Red Eagles and Kolene Steels
Rear of case drilled for Sprag oiling
Relocated Vent
Billet Rear Servo
Etc Etc
Any thoughts?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Type F or Dexron? And WHY??? [Re: topfueldart] #1260426
07/01/12 07:22 PM
07/01/12 07:22 PM
fresno ca
mikeysmopars Offline
fresno ca
My Trans guy said it doesn't foam like dextron or spacific mopar trans fluids do.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Type F or Dexron? And WHY??? [Re: mikeysmopars] #1260427
07/01/12 09:05 PM
07/01/12 09:05 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Maybe a little OT but did you guys ever hear about adding a quart of 30wt. engine oil to your trans fluid? I remember reading an article in Chrysler Power mag about 20 years ago that some race builders say that ATF does not lubricate enough to keep the rollers and bushings from seizing and galling
Sorry for the hi-jack but you don't see too many threads about ATF on here.
Gus
64 Plymouth Savoy
Dana 60
Re: Type F or Dexron? And WHY??? [Re: fourgearsavoy] #1260428
07/01/12 09:20 PM
07/01/12 09:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gus
Hogwash , millions of 833's were built by Mopar and filled with ATF and they are 100% fine with it ....
Re: Type F or Dexron? And WHY??? [Re: JohnRR] #1260429
07/01/12 09:28 PM
07/01/12 09:28 PM
Rittman Ohio
Rittman Ohio
Now thats funny
Where's that guy with the pics of the gears from his dads transmission
Gus
64 Plymouth Savoy
Dana 60
Re: Type F or Dexron? And WHY??? [Re: fourgearsavoy] #1260430
07/01/12 10:01 PM
07/01/12 10:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Mopar ATF + 4. Why ? Well I worked at a Dodge dealer for 24 years and have a nice stock of it and it works great in my car. Ron
Re: Type F or Dexron? And WHY??? [Re: 383man] #1260431
07/01/12 10:24 PM
07/01/12 10:24 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I also use ATF-4...
Re: Type F or Dexron? And WHY??? [Re: topfueldart] #1260432
07/02/12 12:21 AM
07/02/12 12:21 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Type F is supposed to have an additive package with friction modifiers for firmer shifts. I can honestly say I've had transmissions that shifts feel firmer with only a fluid swap to type F. I use Type F with a qt of 30w non detergent in any performance build.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Type F or Dexron? And WHY??? [Re: Evil Spirit] #1260433
07/02/12 12:45 AM
07/02/12 12:45 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Over forty years, never repeat never a trans failure because of lube issues. Never froze a bushing to a shaft etc. Dextron was a friction additive (slicker) and the last thing I want is a band or clutch sliding or slipping as they engage. The faster it locks up the happier I am. Never burned up a clutch or band because it was locked up. Type F
Re: Type F or Dexron? And WHY??? [Re: Cuda367] #1260434
07/02/12 12:49 AM
07/02/12 12:49 AM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Rick at A&A said to use the Dex/Merc... I have all his goodies in my trans, so I am listening to him!
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Type F or Dexron? And WHY??? [Re: Evil Spirit] #1260435
07/02/12 03:37 AM
07/02/12 03:37 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Type F is supposed to have an additive package with friction modifiers for firmer shifts. I can honestly say I've had transmissions that shifts feel firmer with only a fluid swap to type F.'
Yes...
Going back a lot of years...
Re: Type F or Dexron? And WHY??? [Re: JohnRR] #1260436
07/02/12 10:01 AM
07/02/12 10:01 AM
gregsdart Offline
gregsdart  Offline
Gus
Using type F in a transbrake trans I had thrust washers going away very quickly. I rollerized the trans and can run type F now without issue.
A race trans can easily use Dexeron provided the power going through it isn't extreme, (less than 800 hp?) and the thrust washers will appreciate the extra lube. Usually by the time you get to that power level the trans is rollerized anyway.
The factory wanted lube in there for a reason, and I don't argue with the original engineers requirements without knowing exactly what and why I am changing something. The same applies with adding motor oil to type F. You now have an unknown combination, which may be sliprior than standard Dex!
As for slippage, the extra holding isn't really needed till the shift points and torque get really high. A stock trans with a tight torque converter shifting at WOT has to drag a very heavy rotating assembly down a lot of rpm, which means a very big load put on it. I would love to see an engineering type do the math on a stock Hemi shifting at 6000+ rpm and dropping back to say 4500 rpm versus my lighter 528 with all aluminum drum trans shifting at 7100 and only having to pull the motor back to 6600. I bet the stock hemi deal has a tougher situation!
Re: Type F or Dexron? And WHY??? [Re: gregsdart] #1260437
07/02/12 11:06 AM
07/02/12 11:06 AM
Az
Crizila Offline
Crizila  Offline
Az
CRT needs to chim in here. Big John??????????
Fastest 300
Re: Type F or Dexron? And WHY??? [Re: topfueldart] #1260438
07/02/12 01:15 PM
07/02/12 01:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When Pro-Trans first built my trans several years ago they prefered type-F so that`s what I`ve used ever since. When Darrel Parks freshoned it he said he could of put it back together and run it but I didn`t so he freshoned it and installed thrust washers where he could.............that was over 7 years ago and still going strong.
Re: Type F or Dexron? And WHY??? [Re: Thumperdart] #1260439
07/02/12 03:40 PM
07/02/12 03:40 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Guy who used to build my trannies( Jim pauquette) Owner of JPT, and for a long time the builder of about anything fast in stock and superstock Ford racing in the country told me dont ever use anything but Type F.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Type F or Dexron? And WHY??? [Re: topfueldart] #1260440
07/02/12 05:28 PM
07/02/12 05:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Type F..... cheapo type F.... never had a trans fail
and thats with pretty much stock guts with a trans
brake
Re: Type F or Dexron? And WHY??? [Re: B3422W5] #1260441
07/02/12 06:12 PM
07/02/12 06:12 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
Jim Rebuilt my converter last year for me, great guy, Type F fluid is all i use in my 727. Mostly Coan goodies in my tranny and they will tell you the same. you will get a firmer shift and less clutch slippage with the F
Re: Type F or Dexron? And WHY??? [Re: mistress] #1260442
07/02/12 09:38 PM
07/02/12 09:38 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
neither. I use tractor hydraulic fluid. Its cheap i get it by the 5 gallon pal and it works good plus i use it in my tractors
Re: Type F or Dexron? And WHY??? [Re: sturmenater] #1260443
07/02/12 10:12 PM
07/02/12 10:12 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I used Dexron for about 10 years, and then cheap TypeF for about another 10 years. Never even damaged a 727, ever.
Re: Type F or Dexron? And WHY??? [Re: JohnRR] #1260444
07/02/12 11:02 PM
07/02/12 11:02 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Gus
C.A.F.E.
