Re: SS BO29 and LO23 Oil Pan?
[Re: JRepucci]
#126026
09/26/08 11:06 AM
09/26/08 11:06 AM
Posts: 1,101 Ont, Canada
moparo
Ont, Canada
I have one of these I will check the part # if you want.
performancecarrestorations.com
[Re: moparo]
#126027
09/26/08 11:23 AM
09/26/08 11:23 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I 90% that this is the correct fan for a 1968 SS. The bug difference is the configuration of the rivets.
I also believe they used a 383 oil pan.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#126028
09/26/08 11:25 AM
09/26/08 11:25 AM
Troy
West Coast, CA
Here is a shot of the wrong fan....see how the rivets are in a different order.
[Re: Troy]
#126029
09/26/08 11:30 AM
09/26/08 11:30 AM
Troy
West Coast, CA
Here is the correct fan....
[Re: CrazyD]
#126033
09/26/08 10:29 PM
09/26/08 10:29 PM
Troy
West Coast, CA
I just got home and I looked in my copy of "Authenticity Guide 1968 Dart and Barracuda Hemi Super Stock" written by Jim Schild & Larry Griffith. This is a VERY GOOD BOOK if your interested in these cars. ( email jschild@hte.net or www.theautoreview.com ) This book shows many of the different part numbers used in these engine IF they were DIFFERENT than the stock 1968 Hemi engine. It does not list a different part number for a oil pan so you could be correct in saying they used a 1968 Hemi pan. Learn something new everyday.
[Re: autoxcuda]
#126036
09/27/08 12:45 AM
09/27/08 12:45 AM
Posts: 3,115 Sacramento,California
JRepucci
The 1/2 spacers lowered the k-frame and that lowered the whole assembly together... I think they used the hemi pan and just the way the hemi mounted to the k-frame raised the crank center which in turn raised the pan away from the steering linkage.
[Re: JRepucci]
#126039
09/27/08 12:58 AM
09/27/08 12:58 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
The 1/2 spacers lowered the k-frame and the engine compartment... I think they used the hemi pan and just the way the hemi mounted to the k-frame raised the crank center which in turn raised the pan away from the steering linkage.
Ok, something had to change. If a big block B-body 440 pan won't fit a big block A-body, then a hemi pan shouldn't fit either unless the motor was moved up.
There are sure a lot of little tricks on those things. Next time someone sees Bob Tarozzi, thank him for figuring it out.
[Re: 6bblgt]
#126041
09/27/08 10:49 AM
09/27/08 10:49 AM
JRepucci
Thanks Dan,
Do you think a 70-1 hemi pan will work?
Or just take a #187 pan and add 1" or so!
Jason
[Re: HEMI472]
#126043
09/27/08 12:46 PM
09/27/08 12:46 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
who sells the clutch fan? thanks Ed
the clutch fan is only available USED or if someone has an NOS one laying about ...
