96' RAM dies when letting off the gas.
#1259570
06/30/12 05:56 AM
06/30/12 05:56 AM
Posts: 21,651 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
my 96' Ram 1500 with 5.9 magnum dies when I let off the gas. Just started yesterday and now has gotten worse through today. As I as slowing to a stop light or making a turn, the truck turns off and with power steering, that ain't good. Also noticed the operating rpm's are really low, like 200-500rpm at idle instead of 800rpm's I normally see. When I'm in the gas, it drives fine, no hesitation or stalling, just when I let off the gas completly.
Now I did the basics and started with air intake and filter arefine and I don't see any cracked lines. Then and checked the exhaust to see if there was low pressure or lower temp from a blocked or plugged catalytic converter, but that seemed to be fine. Could there be blockage somewhere in the fuel system or something else might be the problem?
Re: 96' RAM dies when letting off the gas.
[Re: migsBIG]
#1259572
06/30/12 10:06 AM
06/30/12 10:06 AM
Posts: 1,487 STL
cdstl
STL
How old is the battery? I had to change the old battery out of my 96 318 Dakota and after that I never had the same problem, that you are experiencing, again.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: snuggles]
#1259574
06/30/12 10:39 AM
06/30/12 10:39 AM
Posts: 905 SD
zrxkawboy
SD
As mentioned, the IAC is a prime suspect. Also, the TPS comes to mind. It also wouldn't hurt to check the fuel pressure.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1259575
06/30/12 02:51 PM
06/30/12 02:51 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Clean the Throttle body and IAC passage. Get all the buildup around the throttle plates and the throat clean in the throttle body. That will fix it 99 out of 100 times. Ron
[Re: migsBIG]
#1259577
06/30/12 08:55 PM
06/30/12 08:55 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
Do what 383man said clean throttle bores and air passages usually fixes them .if not bad IAC motor on rear of throttle body
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: 383man]
#1259580
07/01/12 06:27 PM
07/01/12 06:27 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I had the same problem on my '96 Ram. Problem was the battery. It tested good, but still didn't hold enough charge. Change the battery and you will be good to go.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
[Re: 383man]
#1259583
07/02/12 02:12 PM
07/02/12 02:12 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Yes if the battery voltage gets to low like on a slow crank or it needs a hotshot the PCM will forget where the IAC moter steps were and has to relearn. But if the throttle body is good and clean then it should still idle even if it looses the IAC memory. That would call for a battery and a good throttle body cleanung. Ron
This....
MB
[Re: Paul_Fancsali]
#1259585
07/02/12 09:00 PM
07/02/12 09:00 PM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
I've had this happen several times over the years, with my 1996 Dodge Ram, 5.2 Magnum. It's been the battery (once), the TPS (once) and the IAC (twice). I have a good friend, a Chrysler mechanic, who I consulted the first time the IAC crapped out. He asked me if I was running a K&N filter (I was). He said to get rid of it as the oil can get caught up on the IAC and gum it up.
