Page 6 of 7 1 2 3 4 5 6 7
Re: What do your heads flow? [Re: fishy340] #1259384
07/17/12 09:57 PM
07/17/12 09:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
dang
Re: What do your heads flow? [Re: fishy340] #1259385
07/17/12 10:01 PM
07/17/12 10:01 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
there is some great info here well worth a look
http://www.performancegarage.com.au/blog/cnc-myth-busting
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: What do your heads flow? [Re: bwhackd34] #1259386
07/17/12 10:41 PM
07/17/12 10:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Let me also reiterate that while my bench is calibrated to flow 592cfm in range 6 that is to do so at 25"....if I were deliberately trying to mislead I would base my calculations off of that info....AT THE VERY LEAST...and not bother with the .997 correction factor for flow capacity when flowing at 28".....while not a lot it would gain me some 'flow' but if the numbers aren't genuine I really don't see the point....in the past I had even posted some results that seemed positive BEFORE I verified as I was a bit happy to have them....only to realize why, at that time the gain occurred, and once that issue was corrected and the results proven not actual I deleted that post....I have since ACTUALLY gotten to that point and maybe even a but more but at that time the post was not accurate and was therefore immediately removed....
i'm not going to get into a debate on what your heads could or couldnt flow.
if i had one on my bench....whatever that number was would be what they flowed as far as i was concerned.
i do have one question though about your .997 correction factor and how you're applying it.
are you flowing at 25" and correcting to 28", or are you flowing at 28"?
the reason i ask is, the correction factor from 25" to 28" isnt .997(which i'm sure you know), so i'm just wondering where it fits into the equation.
Re: What do your heads flow? [Re: fast68plymouth] #1259387
07/17/12 10:48 PM
07/17/12 10:48 PM
My Stage V big valve heads fully CNC ported flow +500.
Don't have the exact # because I don't have the charts yet.
Re: What do your heads flow? [Re: fast68plymouth] #1259388
07/17/12 11:10 PM
07/17/12 11:10 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Int. @ .100 .200 .300 .400 .500 .600 .700
c.f.m. 76 157 234 295 334 349 348
Exh.
c.f.m. 59 124 186 225 243 250 253
W-9's ported with a conservative approach and an eye towards mid lift flow #'s. I think they'll work O.K.
The whole motor is a series of compromises since it was built with stuff that was available and affordable over a couple - three year window.
It should have a bigger bore ( it's 4.125 " ), but that could change in the future. It could sure stand more cam ( 260 / 250 @ .050 and .668 lift ) , and it might like a bigger carb too.
But the time slip will be the final arbiter here.
This is the first time I have had a set of heads done up for me , but this is also the most motor I have ever attempted to screw together too......I didn't trust myself to home port them and had too much $$ on the table to risk messing them up.
I think I'll be happy with the end result.
If not , there is always a plan "B".
Re: What do your heads flow? [Re: bwhackd34] #1259389
07/18/12 12:29 AM
07/18/12 12:29 AM
Idaho
LaRoy Engines Offline
Idaho
And if in fact no one else on the planet can get these numbers then I have accomplished exactly what I set out to do two years ago...
Yep, I understand.
Re: What do your heads flow? [Re: LaRoy Engines] #1259390
07/18/12 12:58 AM
07/18/12 12:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
W-9.. CNC ported then touched up... 365 at .700...
small lift and to big of duration cam and small bores
but it is what it is... it doesnt break anything
Re: What do your heads flow? [Re: fishy340] #1259391
07/18/12 01:29 AM
07/18/12 01:29 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well FWIW my B1MC's top out at 452-457cfm, on three different benches over the years. The 99's are at 590 at 1.000". The -1's for the street car are at 370. All of these are hand ported heads no CNC stuff. B1's by Mike Duke,99's by Schumacher racing then Mike Duke.
Re: What do your heads flow? [Re: Al_Alguire] #1259392
07/18/12 01:48 AM
07/18/12 01:48 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
All I can say is, DAMN..............I NEED to drive your car.......
Re: What do your heads flow? [Re: bwhackd34] #1259393
07/18/12 07:12 PM
07/18/12 07:12 PM
detroit area
moderncylinder Offline
detroit area
This has been a subject of other posts on here but I am working on a w9 port design that right now flows upwards of 445@.850" and very near 470@1.00. Velocity down the port is near 325-335 and about 260ish through the throat....port volume around 300cc....still a work in process...
when you stated this,,,,, and then saying 95-96% throat respective to valve size,,, though you never said what your valve size cause its top secret,, but assuming 2.250-2.300,, implys an mca of 2.8-3.0
really its just simple math,, unless what you have stated is incorrect
Re: What do your heads flow? [Re: moderncylinder] #1259394
07/18/12 08:44 PM
07/18/12 08:44 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
This has been a subject of other posts on here but I am working on a w9 port design that right now flows upwards of [Email]445@.850"[/Email] and very near [Email]470@1.00.[/Email] Velocity down the port is near 325-335 and about 260ish through the throat....port volume around 300cc....still a work in process...
Not following your math....if you are figuring the throat as the MCA then assuming a 2.25 valve its area would be 3.974...with a 95% throat the gross area would be 3.775 less valve stem area of .0923(assuming an 11/32 valve) for a net area at the throat of 3.683....if you are figuring the MCA to be elsewhere down the port it could be any size irrespective of these dimensions.....working backward.....with a flow of 450 and an MCA of 3.00 calculated velocity would be 357fps....
Re: What do your heads flow? [Re: bwhackd34] #1259395
07/18/12 08:48 PM
07/18/12 08:48 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
This peein match is very informative.
Re: What do your heads flow? [Re: bwhackd34] #1259396
07/18/12 08:50 PM
07/18/12 08:50 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
By my math.....it has an AVERAGE CA of around 3.56....
V(in fpm)/cfm/12......should get you close....
Re: What do your heads flow? [Re: bwhackd34] #1259397
07/18/12 09:12 PM
07/18/12 09:12 PM
detroit area
detroit area
260/330=.787878
.787878 x 3.683 = 2.90
now thats in general,,, but if you have velocities at those two points,,, and have area at one of those points,, you can "guess" at what the area is at the other
Re: What do your heads flow? [Re: moderncylinder] #1259398
07/18/12 09:40 PM
07/18/12 09:40 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
This is turning into an informative post if you get through the B.S. Quite a few people who know thier stuff are posting. I wont post any of my stuff, its decent I guess but not tops.As some else has said we dont race flow benches or dynos. The numbers dont lie on the time slip.
Re: What do your heads flow? [Re: moderncylinder] #1259399
07/18/12 09:48 PM
07/18/12 09:48 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
Your math is kind of right but you are going the wrong way.....as the CA decreases in size the velocity will increase.....ie. too large of a port equals low airspeed...so while the two airspeeds can be expressed as a percentage of one another the calculations need to be reversed to figure CA
V is cfm/A(sq ft)/60
So with a 3.687 CA
V is 450cfm/(3.687/144)/60
V is 450cfm/.026/60
V is 288 fps
With a 2.90 CA
V is 450cfm/(2.9/144)/60
V is 450cfm/.0201/60
V is 373
Given these speeds....2.90 is roughly 78% of 3.687 and 288 is roughly 78% of 373
Re: What do your heads flow? [Re: bwhackd34] #1259400
07/18/12 09:54 PM
07/18/12 09:54 PM
detroit area
detroit area
so you are figuring out what your velocity is based on math and your airflow,, not the actual measured velocity in the port....
i usually try to stick to actual numbers that i can see and measure
sorry for any confusion,, back to your regular scheduled program....
Re: What do your heads flow? [Re: bwhackd34] #1259401
07/18/12 10:04 PM
07/18/12 10:04 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
With this formula and some creative math you can take the velocity and figure CA....
CA is V(ft per min)/cfm. /12
CA is 320(60) /450
12
CA is 19200/450
12
CA is 42.666/12
CA is 3.56 given 450cfm and 320fps
Re: What do your heads flow? [Re: bwhackd34] #1259402
07/18/12 10:07 PM
07/18/12 10:07 PM
detroit area
detroit area
so now youre saying you have pretty much the same cross section at two places in the port, but the airspeed differs 60-70 fps at those two places?????
Re: What do your heads flow? [Re: moderncylinder] #1259403
07/18/12 10:14 PM
07/18/12 10:14 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
No...that is just how numbers fell out using 450 cfm and a 2.25 valve and the 78% ratio you got from the airspeeds......
