How Much Lift Can New Hemi Cast Iron Heads Take? #1259005
06/28/12 08:55 PM
06/28/12 08:55 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Does anyone know what part number the springs are in the new Mopar assembled cast iron Hemi heads?
I want to know how lift/duration cam I can run with them.
Also are they set up to run unleaded gas?
Thanks.
RS23L7 4-Speed
Re: How Much Lift Can New Hemi Cast Iron Heads Take? [Re: Mopar_Mike] #1259006
06/28/12 11:05 PM
06/28/12 11:05 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
On factory heads they usally put the double .620 lift max flat tappet springs. You need to worry more about piston to valve clearance. They have been putting hardened seats in the steel heads as well. I would pull a spring off to check and be sure. Good luck, poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
