340 engine stamp #1258889
06/28/12 05:06 PM
06/28/12 05:06 PM
Auckland ,New Zealand
c69a Offline OP
c69a  Offline OP
I have 2 340 blocks that were supposed to have been pulled from 1970 Cudas, on the pan rail both stampings start with 0R then the sequence number, should this be either 0B or 0E if they were from Cudas.
what would a 0R have been fitted to from factory?
Re: 340 engine stamp [Re: c69a] #1258890
06/28/12 05:09 PM
06/28/12 05:09 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
0R = 1970 Windsor, ONT = most '70 Dart Swinger 340s & some '70 Duster 340s
Re: 340 engine stamp [Re: c69a] #1258891
06/28/12 05:13 PM
06/28/12 05:13 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
...just like every '69 - '71 440 for sale was pulled from a Six Pack car!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 340 engine stamp [Re: c69a] #1258892
06/28/12 05:40 PM
06/28/12 05:40 PM
c69a Offline OP
c69a  Offline OP
Thanks for that info, At what plants were the 340 engines made?
both of these engine ids start with FW 340 P, is the "W" for Windsor.
Re: 340 engine stamp [Re: c69a] #1258893
06/28/12 07:19 PM
06/28/12 07:19 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
All '70 340 engines were assembled at the engine plant in Windsor.
Can you share the specifics: cast date / partial VIN# 0Rxxxxxx / assembly date FW340 P xxxx xxxx?
Re: 340 engine stamp [Re: c69a] #1258894
06/29/12 02:24 AM
06/29/12 02:24 AM
c69a Offline OP
c69a  Offline OP
Block 1,Cast date 7-11-69, VIN 0R168986, Assembly date FW340P30080166
Block 2, " " 5-28-69, " 0R166459, " " FW340P30160812
Any idea what was the average time for a 340, from engine assemble to car build date for Los Angeles?
Re: 340 engine stamp [Re: c69a] #1258895
06/29/12 03:02 AM
06/29/12 03:02 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Thanks, these two engines ended up in cars built within a couple days but were cast 54 days apart.
cast Wed 5/28/69 + 155 days assembled Thu 10/30/69 + 13 days scheduled car build Wed 11/12/69 0R166459
cast Fri 7/11/69 + 103 days assembled Wed 10/22/69 + 23 or 26 days scheduled car build Fri 11/14/69(Dart) or Monday 11/17/69(Duster) 0R168986
I'll see what I have for 1970 LA - what's your car's VIN# & SPD?
Re: 340 engine stamp [Re: c69a] #1258896
06/29/12 05:56 PM
06/29/12 05:56 PM
c69a Offline OP
c69a  Offline OP
Interesting, must of had a large stockpile of blocks to get through.
VIN HOE 136349 SPD 326 Block cast date 5-26-69,no stamping on front of block,only on pan rail.
