What type of fluid does a manual steering box take?
#1258851
06/28/12 11:09 AM
06/28/12 11:09 AM
Posts: 856 1.5 hours SE of Pittsburg, Pa
geno440
I was wondering what type of fluid a manual steering box from a 68 Barracuda takes? Also, how can you tell when it is full? Do you just fill it up to the plug?
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: What type of fluid does a manual steering box take?
[Re: JohnRR]
#1258853
06/28/12 11:26 AM
06/28/12 11:26 AM
geno440
Yes I do. I have a 69 Dodge service manual. I was looking in it and could not see what they suggested that you fill it with. I am sure it is there, but I could not find it. I was hoping someone knew off the cuff.
[Re: geno440]
#1258854
06/28/12 12:14 PM
06/28/12 12:14 PM
Posts: 1,385 Az
69hemibeep
Az
Unless you mix something up CV joint grease is about as you can get to the old stuff. Warm it and pour it in or use a needle fitting on a grease gun.
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#1258855
06/28/12 03:15 PM
06/28/12 03:15 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
How about 600wt oil that antique car guys use in their steering boxes/transmissions/rears?
Scott
1969 Super Bee, 383/4 speed
[Re: RapidRobert]
#1258858
06/29/12 03:11 PM
06/29/12 03:11 PM
geno440
Thanks for all the help guys.
I finally found what to fill it with in the shop manual I have. (68 Dodge) I must have looked over it 5 times. It says use MOPAR steering box grease. Apparently, they must have sold it at one time. It said if you can't find it to use a quality grade of bearing grease. Surprisingly to me it said and do not use gear oil. It said to pack it in to the top of the teeth on the spline and that is it. So I guess I'll try that with some red grease.
[Re: JohnRR]
#1258859
06/29/12 03:54 PM
06/29/12 03:54 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
It's filled with grease , I remember seeing something posted one time, think it was something that ebooger put in a mag article, about mixing grease and some type of gear oil to make it pourable and fill it that way.
Do you have a factory service manual for any of the cars you own?
The factory used what was called a "pourable grease" that would flow when heated slightly. It was not pourable at room temperature. It does not need to be in a liquid state to do its job properly in the manual steering gear box.
