What type of fluid does a manual steering box take? #1258851
06/28/12 11:09 AM
06/28/12 11:09 AM
1.5 hours SE of Pittsburg, Pa
geno440 Offline OP
geno440  Offline OP
I was wondering what type of fluid a manual steering box from a 68 Barracuda takes? Also, how can you tell when it is full? Do you just fill it up to the plug?
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: What type of fluid does a manual steering box take? [Re: geno440] #1258852
06/28/12 11:14 AM
06/28/12 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's filled with grease , I remember seeing something posted one time, think it was something that ebooger put in a mag article, about mixing grease and some type of gear oil to make it pourable and fill it that way.
Do you have a factory service manual for any of the cars you own?
Re: What type of fluid does a manual steering box take? [Re: JohnRR] #1258853
06/28/12 11:26 AM
06/28/12 11:26 AM
geno440 Offline OP
geno440  Offline OP
Yes I do. I have a 69 Dodge service manual. I was looking in it and could not see what they suggested that you fill it with. I am sure it is there, but I could not find it. I was hoping someone knew off the cuff.
Re: What type of fluid does a manual steering box take? [Re: geno440] #1258854
06/28/12 12:14 PM
06/28/12 12:14 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Unless you mix something up CV joint grease is about as you can get to the old stuff. Warm it and pour it in or use a needle fitting on a grease gun.
1969 Hemi Roadrunner 2nd owner
Re: What type of fluid does a manual steering box take? [Re: 69hemibeep] #1258855
06/28/12 03:15 PM
06/28/12 03:15 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
How about 600wt oil that antique car guys use in their steering boxes/transmissions/rears?
Scott
1969 Super Bee, 383/4 speed
Re: What type of fluid does a manual steering box take? [Re: JohnRR] #1258856
06/28/12 03:34 PM
06/28/12 03:34 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I remember that article. I think he mixed the concoction in an old saucepan and warmed it on the stove just enough to make it pourable.
Re: What type of fluid does a manual steering box take? [Re: Reggie] #1258857
06/28/12 05:03 PM
06/28/12 05:03 PM
a tube of MP high temp lube 4318064 and 2 or 3 ounces of SAE 90 gear oil. With there being low stress on the mesh of the steering gears I think you could get by with most anything
Re: What type of fluid does a manual steering box take? [Re: RapidRobert] #1258858
06/29/12 03:11 PM
06/29/12 03:11 PM
geno440 Offline OP
geno440  Offline OP
Thanks for all the help guys.
I finally found what to fill it with in the shop manual I have. (68 Dodge) I must have looked over it 5 times. It says use MOPAR steering box grease. Apparently, they must have sold it at one time. It said if you can't find it to use a quality grade of bearing grease. Surprisingly to me it said and do not use gear oil. It said to pack it in to the top of the teeth on the spline and that is it. So I guess I'll try that with some red grease.
Re: What type of fluid does a manual steering box take? [Re: JohnRR] #1258859
06/29/12 03:54 PM
06/29/12 03:54 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
The factory used what was called a "pourable grease" that would flow when heated slightly. It was not pourable at room temperature.
It does not need to be in a liquid state to do its job properly in the manual steering gear box.
