Re: ANY HP GUESS ON THIS BUILD
[Re: moparguy7074]
#1258791
06/28/12 10:30 AM
06/28/12 10:30 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Its close to my 493 combo. But I use Indy EZ heads and I use the Indy dual plane intake with an 850 DP. I also use a flat tappet solid cam with 264 & 270 @ .050 and with 1.6 rockers about .630 lift. Its 10.6 comp with quench. I never dynoed it but with running 10.70's so far at 3700 lbs it is making around 600 hp and I feel with a dominator it would make more and thats through the pipes on pump gas. So my guess on your combo would be about 650 hp. Ron
