Serpentine belt squeal????????
#125871
09/24/08 08:53 PM
09/24/08 08:53 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Sorry for not posting this in the truck forum but not too many people go there so I wanted to post it here. My 98 Dakota 3.9 litre has developed a bad squeal. I bought a new serpentine belt, made it worse. As soon as I sprayed belt dressing on the belt it got REALLY LOUD! I bought a new alternator and the problem is still there. If I spray WD40 anywhere on the belt the motor is silent.I'm gonna get a shorter belt to bypass the air conditioner, that will eliminate that. I've done the alternator so bypassing the air conditioner will leave only the crank pulley, fan pulley, and power steering pulley. I already bought a new tensioner pulley also, and the tensioner arm doesn't squeak when I move it back and forth quickly with a long ratchet. Any ideas??
Re: Serpentine belt squeal????????
[Re: ProSport]
#125872
09/24/08 09:14 PM
09/24/08 09:14 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Try a Gator Back belt.We had a few that would squeal and either the cheap belts or the Gators stopped it.That and clean that junk off all the pulleys.Dressing wasnt made for serp belts.Rocky
Chrysler Firepower
[Re: ProSport]
#125881
09/25/08 05:21 PM
09/25/08 05:21 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
I vote tensioner, I've put 2 on the my Caravan in 175,000 mi clean all crap off the belt & pulleys.
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: Devil]
#125883
09/25/08 07:10 PM
09/25/08 07:10 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Had belt squeel on an 01 Dakota with a 3.9 with the Mopar Belt. Swapped to a Dayco belt and much better.
Common sense is a flower that does not grow in everybody's garden
[Re: earlybee]
#125885
09/25/08 10:01 PM
09/25/08 10:01 PM
therocks
Niles , Ohio
I doubt its the tensioner.My 99 has one that wont spring back.I push it tight and never has a noise.Yeah it still has the OE belt thats 10 years old as is the one in the 96 Concord.Not saying it cant be the tensioner.The 3.3s were known for tensioners in the mini vans.They even have a TSB for them.I do this every day.The Dayco or Gator backs are some of the best Ive ever used.Ive installed thousands.So listen to a guiy that had one once or someone that does it thousands of times a year.Its your money and your choise.Oh cleansen and other junk is just a bandaid.It might be ok for a while but would you pour sand in your belys? I think not and its probally less abrasive than that.Rocky
Chrysler Firepower
