8.75 torque specs #1258512
06/27/12 08:47 PM
06/27/12 08:47 PM
Hillsdale,Mi
69swinger340 Offline OP
Hillsdale,Mi
Does anyone have the torque specs for the ring gear bolts and the bearing caps for a 489 case 8.75?
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
Re: 8.75 torque specs [Re: 69swinger340] #1258513
06/27/12 09:27 PM
06/27/12 09:27 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
68 FSM says 90ft lb caps and 50ft lbs ring gear
Re: 8.75 torque specs [Re: Bill MeLater] #1258514
06/27/12 09:55 PM
06/27/12 09:55 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
69 FSM calls for 90ft lbs for bearing caps & 55 ft lbs for the ring gear bolts (LH thread)
this would be correct for the '69 489 case...
Just did mine a few days ago
1MYTGTX
Re: 8.75 torque specs [Re: 1MYTGTX] #1258515
06/28/12 04:14 PM
06/28/12 04:14 PM
Hillsdale,Mi
Hillsdale,Mi
Thanks!!
