is a 25lb hot idel in gear oil pressuer ok? #1258162
06/27/12 08:26 AM
06/27/12 08:26 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline OP
ever since i have been using crane ultra pro rollers
my oil pressure dipped to 25lbs at a hot idel in gear like at a stop light or somthing.sometimes lower.is that ok with u guys
max's out at 80 after 2800
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: BIGSTROKER] #1258163
06/27/12 08:33 AM
06/27/12 08:33 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
What heads and valve train oiling?
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: RemCharger] #1258164
06/27/12 08:36 AM
06/27/12 08:36 AM
500 bb eddy rpm hs rockers 1.6 std rocker oil pluss push rod oiling
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: BIGSTROKER] #1258165
06/27/12 08:40 AM
06/27/12 08:40 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
You have plenty of oil pressure...no worries.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: FlyFish] #1258166
06/27/12 08:42 AM
06/27/12 08:42 AM
tboomer Online work
tboomer  Online Work
Did you ever find your smoking problem?
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: FlyFish] #1258167
06/27/12 08:45 AM
06/27/12 08:45 AM
thanks it always makes me feel better when someone else says it
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: tboomer] #1258168
06/27/12 08:52 AM
06/27/12 08:52 AM
i am 90% sure it is the sixpack air cleaner
i use a kn element but i ran the car with no air cleaner and it was a whole diffrent animal and no smoke just a little puff of black when i jump on it but no blue cloud when i start it
i have to figure somthing out because of hood clearance issues but for now no air cleaner when i
am feeling crazy like every time i drive it!
Re: is a 25lb hot idel in gear oil pressuer ok? [Re: BIGSTROKER] #1258169
06/27/12 09:05 AM
06/27/12 09:05 AM
i was trying to sell this but i mite put it in
