Who's flywheel bolts did you use. #1257983
06/26/12 09:57 PM
06/26/12 09:57 PM
PA
70HemiGTX Offline OP
PA
I pulled my flywheel off and when I pulled my bolts out, they were only holding by about 4-5 threads. Not good. Who makes some that are about 1 1/8" long? I've been looking and most are like .900 or so long. Or even less.
Re: Who's flywheel bolts did you use. [Re: 70HemiGTX] #1257984
06/26/12 10:20 PM
06/26/12 10:20 PM
AndyF Offline
AndyF  Offline
ARP has ones that are the correct length for Mopar applications. Like you say, most are either too short or too long.
Re: Who's flywheel bolts did you use. [Re: AndyF] #1257985
06/27/12 06:02 AM
06/27/12 06:02 AM
metro detroit
turner Offline
turner  Offline
metro detroit
went to Mancini racing on lunch and asked for some flex plates bolts, they told me that the factory style might never be available again. Instead he sold me some of the 12pt ARP bolts, after using these I wouldnt use a factory style bolt unless that was all I had, the 12pts dont slip and bust your knuckles and they dont get all rounded off like they were used a hundred times. The Arp bolts is all I would use now!
Re: Who's flywheel bolts did you use. [Re: turner] #1257986
06/27/12 08:59 AM
06/27/12 08:59 AM
Mountains of NM
65superstock Offline
Mountains of NM
ARP on mine as well
=Jason
Re: Who's flywheel bolts did you use. [Re: 65superstock] #1257987
06/27/12 09:32 AM
06/27/12 09:32 AM
South Lyon, Michigan
6bblRoadrunner Offline
ARP here as well.
Re: Who's flywheel bolts did you use. [Re: 6bblRoadrunner] #1257988
06/27/12 10:59 AM
06/27/12 10:59 AM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
Another ARP user here but I don't share the love for the 12 point heads. You never going to round the head off of a 6 point bolt IF you use a good 6 point socket.
Re: Who's flywheel bolts did you use. [Re: 70HemiGTX] #1257989
06/27/12 02:43 PM
06/27/12 02:43 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
