LA SB ADJ rocker arm oiling question #1257975
06/26/12 09:53 PM
06/26/12 09:53 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hi, this concerns the oiling, I have the pro-comp adj rockers.. now the shafts oil like the stockers.. the push rods also have oiling holes.. so question is should i use the the push rods with the oiling holes or not.. the arms do have holes in the to oil the ball as well.
any way thats how they were removed.. I am installing a new set of stock rockers as with new shaft with push rods with the oiling holes.. I am currious is the previous set up was right..
Re: LA SB ADJ rocker arm oiling question [Re: Dakota_Don] #1257976
06/27/12 12:06 AM
06/27/12 12:06 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I run my pro-comp rockers with push rods that have oiling holes in them. My lifters also are the type to send oil up. Not all lifters will send oil up through the push rods. But anyway my rockers get oil from both push rods and rocker tube. Been a couple of years and working great so far.
Re: LA SB ADJ rocker arm oiling question [Re: Dakota_Don] #1257977
06/27/12 08:34 AM
06/27/12 08:34 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If your lifters do not have the passage in the plunger to feed the hollow push rods they will not feed oil to the top anyway and the top end will oil as per normal. You sure don't need nor want both oiling.
Re: LA SB ADJ rocker arm oiling question [Re: MoparforLife] #1257978
06/27/12 08:34 PM
06/27/12 08:34 PM
Alton, IL
Alton, IL
my lifter have oiling holes as well.. just checking to see if thats ok
Re: LA SB ADJ rocker arm oiling question [Re: Dakota_Don] #1257979
06/27/12 08:35 PM
06/27/12 08:35 PM
Alton, IL
Alton, IL
my lifter and shafts both oil.. soo is that good or bad.. i was told only need the shaft oiling system, and push rods with out the holes
Re: LA SB ADJ rocker arm oiling question [Re: Dakota_Don] #1257980
06/28/12 12:59 AM
06/28/12 12:59 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Banana groove shafts will make the rockers last a long time
Re: LA SB ADJ rocker arm oiling question [Re: Dakota_Don] #1257981
06/28/12 07:36 PM
06/28/12 07:36 PM
Upper Midwest
Upper Midwest
IMO you are 'bleeding' off a lot of unnecessary oil to the top of the engine. Could actually effect the oil pressure somewhat. Shaft oiling works well, no need for the through push rod oiling. A lot restrict oil to the top and here you are increasing it.
Re: LA SB ADJ rocker arm oiling question [Re: MoparforLife] #1257982
06/28/12 09:34 PM
06/28/12 09:34 PM
Alton, IL
Alton, IL
ya that what i was thinking when i saw the push rods with the oil holes.. fig i didnt need it and the shaft oiling would work good,, jus wanted a second opinion
