Aluminum vs.Steel Dampers #1257896
06/26/12 07:24 PM
06/26/12 07:24 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Can someone give the low down on the pros and cons of these two in comparison? I see that ati makes them out of both materials. Im sure the aluminum will help with performance to a degree but has to come with negatives or they would all be aluminum no?
Re: Aluminum vs.Steel Dampers [Re: Hot 340] #1257897
06/27/12 12:46 AM
06/27/12 12:46 AM
Cab_Burge Online work
Cab_Burge  Online Work
Years ago I tested a all aluminum BHJ balancer on a NHRA class leagl 340 stocker motor versus the stock balancer,13 lbs versus 7 lbs, no stinking changes on torque or horespower none at all measured Looking back now we should have done that test at the track, not on a engine dyno As far as which one is better at absorbing crankshaft shocks I bet the heavier one is better, maybe not I have both types of ATI dampeners on my motors, I can't tell the differences between them. The motors are not twins so not a decent comparision at all
Re: Aluminum vs.Steel Dampers [Re: Hot 340] #1257898
06/27/12 01:07 PM
06/27/12 01:07 PM
Locomotion Offline
Locomotion  Offline
From everything I've read/heard, I would agree with Cab that the heavier one will absorb vibrations/harmonics better than the lighter one. Solid aluminum hubs with are said to contribute to broken cranks and other problems due to no dampening properties. An ideal set-up would be an aluminum center with a steel outer ring which would provide the best of both worlds - lighter weight for faster reving with a heavier outer ring to dampen the vibrations and harmonics. But since the benefits would be minimal with an aluminum center, I simply use a quality steel/steel balancer for durability. (Weight reduction closer to the center of rotation provides less benefit than weight removed further out from the center.)
Re: Aluminum vs.Steel Dampers [Re: Locomotion] #1257899
06/27/12 01:31 PM
06/27/12 01:31 PM
dogdays Offline
dogdays  Offline
The heavier damper will help your crank last longer.
R.
Re: Aluminum vs.Steel Dampers [Re: dogdays] #1257900
06/27/12 05:30 PM
06/27/12 05:30 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thnks guys... Thats what I needed to know.
