Re: destroyed another bb-powerglide flexpate again ideas?? [Re: ROSSIO] #1257023
06/25/12 06:07 PM
06/25/12 06:07 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
WWWWOOOOOOOO i just saw that meizere flexplate fp30608--man $483.00
my 149182 tci for $196.00 looks good for now--if it breaks again--i will buy the meizere 30608
Yeah I need one that is custom to my crank so add a bit to that little gem for "special set up". Add the Browell bellhousing at a nifty $2200 for aluminum or $1300 for steel. I am feeling the pain, R5 crank to NCR convertor and R5 block to a Bruno.
OUCH!!!
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: HEMIFRED] #1257024
06/25/12 06:11 PM
06/25/12 06:11 PM
ok
mopdragster Offline OP
ok
392 from jegs with racer discount. won't ship till 7-6 though
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257025
06/25/12 08:01 PM
06/25/12 08:01 PM
Iowa
coronetville Offline
Iowa
use j.w. one piece
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: coronetville] #1257026
06/25/12 08:09 PM
06/25/12 08:09 PM
Arizona
Chris'sBarracuda Offline
Arizona
http://www.reactorproducts.com/mainProducts.html
Replaceable ring gear.. 130EI8H 8 hole
Used these since I went to a Glide.. Early 90's.. Not one failure..
Talk to Olan @ Reactor, or you can buy through Coan..
http://www.coanracing.com/Catalog.asp?CatClass=40MC
Chris..
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: Chris'sBarracuda] #1257027
06/26/12 11:15 AM
06/26/12 11:15 AM
ok
ok
I had forgot about them I will give them a call. Thanks for all the help
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257028
06/26/12 03:01 PM
06/26/12 03:01 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Just came to mind reading the tread. I have always ran a start retard. The 7AL3 was fixed at 25 degree retard which was too much and I had to do something else. The 7531 allows you to adjust the start retard. Retard 10-15 degrees and it works great. Have had up to 17.5:1 compression and ran on 12 volts for a while like that. Then went to 16 volts. Have hurt a starter with the poorly made JW bell but knock on wood never the flywheel.
Leon
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: Leon441] #1257029
06/26/12 03:54 PM
06/26/12 03:54 PM
ok
ok
i agree I have the new pro grid and am pulling out 11 degrees till 500 rpm so motor has 25 degrees cranking and 36 running. kinda cool racepak shows cranking rpm at 286 with 16v battery.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257030
06/26/12 11:02 PM
06/26/12 11:02 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
just got my flexplate in and all back together,starts nicer--esier,i think.going to the track thursday,i drove it around the plat,its nice cruisin around in a 1100 hp car.
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
