Manual disc/drum brakes issues on hemi cuda, help! #1256936
06/25/12 02:33 AM
06/25/12 02:33 AM
KillerCuda Offline OP
hey folks, i am just finishing up my resto on our '70 cuda convertible, upgraded with a recent eddie haines built 426 hemi. anyway, i ditched the powerbrakes for obvious reasons. i kept the ssbc front discs and calipers, rebuilt the drum rears, installed a 1" bore master cylinder, and still have the proportioning valve to the rears from ssbc. i have a solid pedal after bleeding the system, but MAN, standing on that pedal barely slows her down. even the rears would not lock up no matter what the setting on the prop valve. pedal ratio appears to be 6to1. i am at a loss for ideas here, i have done a TON of internet searches, as well on here, i see a lot of people with my setup (or close to) doing just fine. any ideas? only variable is i am not sure of the caliper pistons/area.(ssbc 4 pistons). any, and all advice welcome, would love to get this baby on the street!
thanks folks,
davey
here is a link to the fire up:
http://www.youtube.com/watch?v=yGhFH91HIQo&feature=youtu.be
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: KillerCuda] #1256937
06/25/12 11:54 AM
06/25/12 11:54 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This is a common problem. Because SSBC uses small bore calipers, a 15/16" bore master cylinder will help.
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: DoctorDiff] #1256938
06/25/12 07:36 PM
06/25/12 07:36 PM
thank you!
what would you suggest, new calipers with my 1" bore master or a new master with a smaller bore and keep the calipers? i want the best brakes possible, is there a 7/8" bore for mopar? so far, i am having trouble locating one, i kind of want it to look period correct, ie, no plastic if possible. i also have an adapter to go from four bolt to two bolt as far as masters go.
thanks again for the help doc!
davey
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: KillerCuda] #1256939
06/25/12 08:58 PM
06/25/12 08:58 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock 7/8" and 15/16" bore aluminum master cylinders.
'73-'75 A-bodies with power disc brakes used a 4-bolt iron 15/16" bore master.
I would also look into EBC "yellowstuff" brake pads. I think SSBC uses a late '60s Mustang spec (4-piston) front caliper.
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: DoctorDiff] #1256940
06/26/12 09:57 AM
06/26/12 09:57 AM
thanks again doc, so the power master from the a-body's will still work with my manual linkage? it has the depth in the piston to hold the rod? unlike most power mc's i have seen that are shallow? (mopars are newer to me, mostly a pontiac guy)
i measured line pressure last night at the front calipers, 700psi under what i felt was 'normal' foot pressure, (no pedal gauge for lbs applied), and what i would call a 'panic stop' was about 1200psi.
i took the pads out, roughed them up on a flat surface, and scuffed the rotors (spinning them with a drill and lightly deglazing them with emery cloth) and it seemed to help. so, maybe the 15/16ths master and some yellow pads might get me there you think?
thank you so much for the help, i really appreciate it......
davey
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: KillerCuda] #1256941
06/26/12 12:39 PM
06/26/12 12:39 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, every 15/16" bore A-body master I have seen has the receiver groove machined into the back of the piston.
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: KillerCuda] #1256942
06/26/12 01:42 PM
06/26/12 01:42 PM
AndyF Offline
AndyF  Offline
I know you don't want to hear this, but this is a very common problem when using a brake kit that is made up of generic parts. People buy the generic brake kits because they are cheap, but if they don't work, cheap isn't a good price.
DoctorDiff sells Mopar brake kits that work. You're lucky that he is kind enough to jump on here and help you solve a problem with a kit that isn't even his.
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: AndyF] #1256943
06/26/12 07:38 PM
06/26/12 07:38 PM
@ andy, i am well aware this is not his problem, nor is he obligated to help me. i bought the car with this kit on it, and i am just doing the gearhead thing and working out the bugs so my car works. if i would have started from scratch myself, i would of course sought an expert such as himself. i have also thanked him at least twice in every post, and will continue to thank everyone here who is kind enough to help a new mopar brother out. i would hope 'luck' isn't a deciding factor on people chiming in to help others on here, maybe i should have been more specific in my first post. but, thank you for reminding me to always say please and thank you.
and on that note, thanks doc, i will decide what to do next now that i have some info at hand......
davey
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: KillerCuda] #1256944
06/26/12 08:02 PM
06/26/12 08:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I really don't mind answering any tech question if I have something to contribute.
I'm also curious about the EBC yellow brake pads, as they are available for the calipers I sell.
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: DoctorDiff] #1256945
06/27/12 08:42 AM
06/27/12 08:42 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If the small bore master cylinder doesn't work, check the pedal ratio. I had this problem on a 64 Plymouth and the pedal ratio for manual brakes was different than power (after trying three different master cylinders). The attachment point for the pedal and push rod were different. Not sure about E bodies, but early B's are definitely different.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: Dads426] #1256946
06/27/12 10:24 AM
06/27/12 10:24 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unlike early B-bodies, power and manual brake E-bodies share the same pedal.
Re: Manual disc/drum brakes issues on hemi cuda, help! [Re: DoctorDiff] #1256947
06/27/12 10:27 PM
06/27/12 10:27 PM
thanks for more info guys, just to share, so others can see, my ssbc 4 piston calipers are part number 09515, it appears to be an older model they made, and it uses pads from the 64-67 mustang, amongst other plymouth and amc models, mimicking the kelsey hayes of the era. my pedal ratio is 6 to 1, and from what i could tell, like the doc said, all e bodies are the same? pretty sure my car was born a manual drum car, converted to power disc/drum some years back, now it is manual disc/drum.
doc, still looking into finding the yellow stuff pads locally, now that i am sure of what i have, i will let this thread know what i do and what results so others can see as well.
thanks again for chiming in, wouldn't have got it straight without ya!
davey
