drilling TQ throttle plates? ***UPDATE*** #1256766
06/24/12 10:31 PM
06/24/12 10:31 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ok Im running 440 at 10.1cr, eddy heads, single plane intake, PCV hooked, choke hooked, and a purple shaft ...661 cam. (250 something @50, .557 lift), fuel pressure reg set at 5.5psi. Initial timing set at 20* total limited at 38*.
Ok with the transition slots square I have a ridiculously low idle of about 500 and usually less, which it will do but not well when running around town. Its much happier when it idles at 750 to 800 rpm. The mixture screws are set at between 1.5 to 1.25 out. after that I dont notice any other gains.
To get the idle speed I would like the transition slots are severely over exposed.
I dont want anymore initial, and I have tried it up to 30* but really was unhappy with the overall results.
I have spent the last 2hrs doing google searches trying to figure out the best method to get about 300 more rpm at idle am I at the point of drilling?
Just for the record, no vacuum leaks and NO im not switching off my tq.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: drilling TQ throttle plates? [Re: kilroy] #1256767
06/24/12 10:35 PM
06/24/12 10:35 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Do you have vacuum advance hooked up?
It worked for me in a similar situation with a TQ.
Re: drilling TQ throttle plates? [Re: kilroy] #1256768
06/24/12 10:37 PM
06/24/12 10:37 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
try adjusting the secondaries.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: drilling TQ throttle plates? [Re: DARTH V8Я] #1256769
06/24/12 10:40 PM
06/24/12 10:40 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
which part, the stop, the amount they open, what?
I used to do this on a holley but never heard of it on a TQ.
Re: drilling TQ throttle plates? [Re: Dan Halen] #1256770
06/24/12 10:42 PM
06/24/12 10:42 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I have the vacuum hooked up, but tuned out so it only comes in about 13hg. I dont like it dictating my idle, I know there is a lot of controversy over this but this is how I like it.
Oh and I have 7-8" vacuum at idle.
Re: drilling TQ throttle plates? [Re: kilroy] #1256771
06/24/12 10:42 PM
06/24/12 10:42 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Before drilling, or trying a different carb (like the Demons which have the adjustable idle-eze baseplate), I would suggest trying a small 4 hole spacer.
I just put one on my car and was able to close the primary butterflies quite a bit and keep the same idle speed (also adjusted the mixture).
I got mine for 14 delivered from ebay, its a 1/2" phenolic.
Re: drilling TQ throttle plates? [Re: Exit1965] #1256772
06/24/12 10:44 PM
06/24/12 10:44 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I would like to but 71-74 chargers are a bear for hood clearance. Thats partially why I run the Street Dominator intake, it has really low carb height.
Re: drilling TQ throttle plates? [Re: kilroy] #1256773
06/24/12 11:06 PM
06/24/12 11:06 PM
IN
ahy Offline
ahy  Offline
IN
With a big cam they benefit from the holes... I'd go ahead and drill it.
Re: drilling TQ throttle plates? [Re: ahy] #1256774
06/25/12 12:35 AM
06/25/12 12:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Is this an auto trans or standard? If standard, go ahead and drill. If auto, what is your in park/neutral idle vs in gear idle?
Re: drilling TQ throttle plates? [Re: DaytonaTurbo] #1256775
06/25/12 12:52 AM
06/25/12 12:52 AM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Standard. now.
Ive seen a lot of stuff on line from the extra pcv to create a vacuum leak, to drilling the base plate and installing a jet, which would all work but drilling and if I had to brazing the plates seems just as easy.
Just making sure Im not missing something here.
Re: drilling TQ throttle plates? [Re: kilroy] #1256776
06/25/12 02:02 AM
06/25/12 02:02 AM
Manitoba, Canada
Manitoba, Canada
Worst case scenario you replace your thermoquad base plate with a donor piece if you ever need to undo it and don't want to solder, braze or jb weld the holes shut.
Re: drilling TQ throttle plates? [Re: DaytonaTurbo] #1256777
06/25/12 12:10 PM
06/25/12 12:10 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
I have done alot of research on this particular case and here is what I have discovered with you only running 7-8 inches of vacuum your TQ now thinks it is on a much smaller engine. Carter and Edelbrock carbs. were designed to run with 12 inches on up. The reason your idle is so low is because your not pulling in enough air and gas into the intake thru your idle circuts. The idle air bleeds are too small and you would most likely have to go to bigger jets to compensate for the low vacuum that is not pulling enough fuel thru. Also depending on which springs you have in the TQ you will have to go to probably the 3 or four inch and not the orange which is rated at 5 inches which may cause your rods to lift up some at idle and then will be bypassing the idle circuts. So drilling the plates is the most likely thing to do but your not doing anything to the fuel thing just the air thing. Does any if this make sense? And by the way, I have a 94 Chrysler Power magazine that has an article on Big Cam Blues. If I could post this entire article I would, it is very helpfull!
Re: drilling TQ throttle plates? [Re: superbeedave] #1256778
06/25/12 12:37 PM
06/25/12 12:37 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I drilled 1/16" holes I believe on my TQ with a MP508 cammed 340-4spd and also trimmed one coil off of the metering tree spring to make it lighter. 22 intial/38 total timing advance also with no vacuum advance hooked up. These mods and adjustments do work and normally help with larger cams on street cars.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: drilling TQ throttle plates? [Re: kilroy] #1256779
06/25/12 12:37 PM
06/25/12 12:37 PM
The amt they're open. Not saying I know that's the fix but that's what he meant
Re: drilling TQ throttle plates? [Re: kilroy] #1256780
06/25/12 01:49 PM
06/25/12 01:49 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Look up this thread of mine.
Much smaller cam (238/244 @ 0.050") but same problem never the less.
Car has done a lot of sitting around, due to other reasons, but I'm about to re-start the work on it. Will be up and running within the next week or so, and this particular issue is near & dear to my heart! LOL
I'll be watching your thread...
Re: drilling TQ throttle plates? [Re: superbeedave] #1256781
06/25/12 08:16 PM
06/25/12 08:16 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
The tree is not the problem it is not bouncing at idle, but anyways I dont quite think this is right. Idle circuits are Idle circuits. You maybe right about them not pulling enough fuel or air but changing the rods, springs, or main jets will not effect the idle circuit because there is no air flow pulling fuel through the main circuits and boosters. Kinda like a holley's PV circuit is active during idle but since no fuel is being pulled through the boosters it doesn't change the idle circuit richness (but as soon when fuel starts flowing through the boosters all that changes.)
I can idle, I just need some MORE idle rpms without exposing more of the transfer slots.
Re: drilling TQ throttle plates? [Re: Diplomat360] #1256782
06/25/12 08:26 PM
06/25/12 08:26 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I actually saw your post when searching, though its surprisingly hard to find! Yours is a good post. Later tonight if no one comes up with a good answer ill drillem see how it idles.
Re: drilling TQ throttle plates? [Re: kilroy] #1256783
06/26/12 12:16 AM
06/26/12 12:16 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
The other option to consider would be to drill out the normal air by-pass passages even further (the ones I showed circled in RED in my photos) and then enlrage the passege in the base plate that actually feeds air into the motor as it by-passes the throttle blades.
Since I have no access to any type of drilling equipment (and boy, you have to be super careful and precise there, I'm thinking a machinist type of a job) I simply couldn't try this.
The additional problem, certainly in my setup, is the fact that I am running an open plenum spreadbore-to-squarebore adapter. Therefore, the signal, as little as there is of one with the bigger cam is bled off even further by the opposite bank. I am currently on a hunt for either a 4-hole spread-to-square bore adapter, or a Canton Racing 85-254 spacer which should preserve some of the signal. Either way, it's a crap-shoot...
Re: drilling TQ throttle plates? [Re: Diplomat360] #1256784
06/26/12 01:20 AM
06/26/12 01:20 AM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ok boys here we are. I didnt want to drill the air bleed by pass in the base plate because I wanted to be able to put the carb back to normal so I did drill the throttle blades.
I started at 1/16 which didnt do boo.
I moved up to 1/8 because when I unplugged the pcv hose and cranked out the idle mixture screws it responded with more idle speed.
What I ended up with was 9/64 holes and somewhere between 2.5 and 3.25 turns on the idle mixture with an idle of 850rpm. I also have less than .035 (give or take, its hard to hold a carb upside down and compare with a feeler gauge) of transfer slot exposed, just barely over square. The car seem to be happy, so am I.
I will take it for a long drive later this week and update more.
Again my original was 1.5 turns on mixture screw at 850rpm but with over half of the transfer slots exposed.
Im sure I could drill some tubes, but I think essentially I am doing the same thing only not messing with the other circuits or transition into those circuits by not drilling out the bleeds on the low and high speed.
No matter how you look at it, it takes a certain amount of air+fuel to equal speed.
Re: drilling TQ throttle plates? [Re: kilroy] #1256785
06/26/12 12:58 PM
06/26/12 12:58 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I'll be curious to hear your feedback on how the part throttle cruise is when driving down the road. It may need more primary jet or, the metering rod tree may need adjusted to compensate for the additional air being brought in by the primary throttle plate holes you drilled.
