69 440 detonation issues #1256438
06/24/12 02:56 PM
06/24/12 02:56 PM
St. Paul, MN
440 4 me Offline OP
440 4 me  Offline OP
St. Paul, MN
I have a 69 440 that is fairly stock. It has a few updates/upgrades including an electronic ignition, Hughes camshaft (basically an upgrade over stock HP camshaft), forged pistons (flat tops) and Mopar dual plane intake. It runs stock exhaust and carb. I had it out for the first time in a couple years last night. I put fresh fuel in it (pump gas - 91 octane) and I added a container of octain booster. Still, it detonates when I accelerate. I have not checked the timing on it yet (I know, I need to do this) but I would think if I had it advanced too far that it would crank over hard - which it does not. Any suggestions would be appreciated.
Thanks,
440 4 me
Re: 69 440 detonation issues [Re: 440 4 me] #1256439
06/24/12 03:04 PM
06/24/12 03:04 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Thanks,
440 4 me
Octane booster does nothing! You need to check timing first.
Yes I live in Michigan, so there is still 1 light on
Re: 69 440 detonation issues [Re: 440dart] #1256440
06/24/12 10:21 PM
06/24/12 10:21 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I agree with 440dart. Also the mp distributors they sell have way way too much advance in them if that is what you have. You will need to get it recurved if so.
Re: 69 440 detonation issues [Re: viperblue72] #1256441
06/24/12 10:29 PM
06/24/12 10:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Exactly , if it is the old MP distributor it will have close to 30 degrees of mechanical advance in it , you need to get a timing light on it , also disconnect the vac advance if you have it connected till you get it all sorted out .
