Grease rear shackle bushings before install?
#1256425
06/24/12 02:17 PM
06/24/12 02:17 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
Should poly bushing have grease applied to the inside before you install them? I am installing new poly bushing and leaf springs in a 69 Bee.
Thanks!
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
Re: Grease rear shackle bushings before install?
[Re: Mad_Scientist]
#1256426
06/24/12 05:34 PM
06/24/12 05:34 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Won't hurt anything, but not necessary either.
I just did the leaf springs on my GTX. Came out great, nice project, made a big difference.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: BigBlockMopar]
#1256428
06/24/12 06:57 PM
06/24/12 06:57 PM
Mad_Scientist
Itasca, Texas
Thanks for the direction guys!!
[Re: Mad_Scientist]
#1256429
06/24/12 10:31 PM
06/24/12 10:31 PM
Posts: 4,323 NY NY
340duster340
NY NY
the poly bushings should come with some "special" grease....i forget what exactly it is.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: BigBlockMopar]
#1256430
06/25/12 02:53 AM
06/25/12 02:53 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Every poly-to-metal contact-area should be greased. Most important are the outsides of the bushings. Lack of sufficient grease here will cause squeaks.
Even beyond the squeeking is you want the suspension to move free and without bind up and down. You can over tighten the shackles and cause binding. That keeps the suspension from being repetitive. The proper torque and keeping them lubed are critical in our leaf spring race cars we run.
[Re: autoxcuda]
#1256431
06/25/12 10:18 PM
06/25/12 10:18 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
do you know the torque rates off by hand?
[Re: autoxcuda]
#1256434
06/26/12 01:13 AM
06/26/12 01:13 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The shackles have shanks so you can't overtighten those. The fronts have sleeves as well. Put a lot of grease where the bushing meets the hanger.
Mopar to the bone!!!
