hex head bolts stealth heads are there any? #1256413
06/24/12 01:51 PM
06/24/12 01:51 PM
Minnesota
72blubird Offline OP
Minnesota
hex head bolts stealth heads are there any for those aluminum heads? I know the head needs to be smaller than stock size but really want the hex head look. Anyone know?
What was I thinking....
Re: hex head bolts stealth heads are there any? [Re: 72blubird] #1256414
06/24/12 02:45 PM
06/24/12 02:45 PM
wyo
70 vcodecuda Offline
wyo
arp make both 12 point and 6 point
they won't have correct head marking but you will need the washers that come with the arp's
440 source also sell's a lees expensive set (half the cost of arp's)
but not sure if they are 6 os 12 point
1970 Cuda V code 4speed Shaker 2009 Challenger RT 2003 Ram 2500 Quad Cab CTD
Re: hex head bolts stealth heads are there any? [Re: 70 vcodecuda] #1256415
06/24/12 02:53 PM
06/24/12 02:53 PM
tboomer Offline
tboomer  Offline
Re: hex head bolts stealth heads are there any? [Re: tboomer] #1256416
06/24/12 10:07 PM
06/24/12 10:07 PM
Minnesota
Minnesota
Thank you
