Rod clearance Oppinions needed
#1255922
06/23/12 09:55 AM
06/23/12 09:55 AM
Posts: 466 Ohio
fiddlestix
Ohio
I am building a mostly street driven 493 stroker with aprox. 600hp. After checking the rods I have (4 rods) .0026 clearance (2 rods) .0027 clearance (1 rod) .0029 clearance (1 rod) .0033 clearance My question is...... is .0026 too little clearance and is .0033 too much clearance? Thanks for any help you can give me.
Re: Rod clearance Oppinions needed
[Re: 440Jim]
#1255924
06/23/12 10:22 AM
06/23/12 10:22 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
minimum you want to see would be .015-.017 sounds like you're fine.
more has never been a problem. too little and bad things happen.
**Photobucket sucks**
[Re: 70Cuda383]
#1255925
06/23/12 10:32 AM
06/23/12 10:32 AM
70Cuda383
Marysville, O-H-I-O
Although, I'll admit, that much difference is puzzling. check the bearings to make sure they're not upside down on a rod or 2. if it's upside down/backwards, the bearing may ride on the chamfer of the crank and not let the rod go all the way over against the crank.
[Re: fiddlestix]
#1255927
06/23/12 12:25 PM
06/23/12 12:25 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
What are the mains? Is this crank .010 undersized or new?
"Just a Bracket car dressed up like a streetcar"
[Re: fiddlestix]
#1255931
06/23/12 01:55 PM
06/23/12 01:55 PM
Posts: 4,206 New York
polyspheric
New York
I think you're safe. However: do not start with high viscosity oil "just to be sure".
Boffin Emeritus
